You will need to check you washer drain hose and make sure it is only inserted into your house drain pipe in the wall no deeper than 4-6 inches, alternately your house drain needs to be as high as the top of the washer lid. Be sure to secure your drain line from the washer to one of the water shut off fittings with a zip tie. You are most likely experiencing a siphon action because the washer hose is inserted too deep in the house drain. Pleazer Appliance...
drain the carbs out so they fill with fresh fule and retry starting the bike if that still wont get you going wip out the plugs and tip a cap full of fule down each plug hole replace the plugs and give that a try it should at least try to start after this,,,it could be that the pistons are dry or the jets in the carbs are blocked up,,if its the carbs jets blocked up turn off the fule drain the carbs and fill the carbs with carb cleaner let that stand a day or so then drain the carbs and fill up with fresh fule,,,to restart the bike,,,
THere is no gas in the fuel rail at the time gas is running out. WHen you fill the tank, it needs to pump for a while so fuel can fill up the rail then the Fuel distributor so it can build up pressure for the injectors to work properly. It need to continue cranking at least 2 minutes. However you don't want to run out the battery, so can just turn on the key to hear the sound of the fuel pump stops, then turn key off turn key on again. Repeat this for 6 times then start the engine. The reason for it is that every time the key is on it turns on the fuel pump to prime the line then turns pump off after a specific time, then it turns on again only when key is at ignition position. By doing this you help to pump gas into the fuel rail instead of the starter continue cranking draining down battery fast. Cheers.
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
