Hi Mike,
Go To this Site and Buy Your any type of Printer Requirement :
Epson Stylus Photo R200 Ink Jet Printer C11C546011
SOURCE: Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
SOURCE: Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.
Open EPSON Print CD
2.
When CD is ready for printing do the following:
3.
Select Print from the File menu
4.
When “The EPSON printer driver dealing with CD
printing is not installed” is displayed – click OK and select Manual Print
5.
Set Paper Size to A4 and click OK
6.
In Layout select Print Settings
7.
In Media Type select CD/DVD
8.
Then press Print
Th
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
SOURCE: Epson Stylus Photo R300 CD/DVD Tray
The answer to this is to insert the cd tray then click to print then when its about to print put some light pressure with your fingers and you will see the tray will go in and it willl print just fine does it with mine all the time so thats what i do to rememedy the problem...good luck
SOURCE: I need a repair service for EPSON stylus photo
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
