And anytime a show comes on that is RATED HIGHER THAN TV-14 the screen turns completely blue and says that i need to enter my 4 digit passcode. PLEASE HELP ME? My boyfriend is going completely bonkers! I am in need of ALL of my options in being able to fix this VERY BIG DILEMMA that we have. Any suggestions at all help at this point. He's ready to just give up and get rid of my tv. Please any one help me figure this out and Thank You very much...
Someone setup the parental restrictions.
The remote you can look up and most likely order off of Amazon using the brand and model number...
You'd have to somehow convince Mitsubishi to give you a "universal code" or other override or much easier, usually, get the code from the people that you bought it from...
SOURCE: Mitsubishi WS-65611
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
SOURCE: I have a Mitsubishi Rear Projection tv (vs-50705).
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
SOURCE: Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
SOURCE: I have a Mitsubishi WS-65711 that is six years
Go by number on your ICs If they are STK392-570 then use STK392-570 only! Call Mats for parts 10.95 each 1-800-628-1118 They are Big Black ICs mounted on Big Aluimmim heat sink will have STK on them!
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
