Jabra Solemate Speaker System - Wireless Speakers - Black - 120 Logo
Daniel Bezzina Posted on Feb 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Major static with bluetooth speaker
When I have speaker connected with usb cable to my laptop while charging there is no static...when I unplug major static... I removed device and then paired it again and that worked for few minutes then right back to static. I have new dell inspiron 15 windows 8...
Anonymous232
Level 3:
Genius:
  • Master 1,552 Answers
  • Posted on Apr 19, 2014
Anonymous232
Master
Level 3:
Genius:
Answers
1552
Questions
Helped
270301
Points
2945
With your "new" computer, you get up to 90 days of "free" technical support, via telephone, from Dell. Telephone them.
Trying to play through cable adaptor to the Travelocity TVBP-BTS-BK speaker
The mini-USB port may be for power/charging only. It probably isn't a data port. Your best solution is to get and use a USB Bluetooth adapter for your laptop. You will need to find one that is compatible (driver compatibility) with the OS on your laptop and has the same or a higher Bluetooth standard. (For example, Bluetooth 4.0 Low Energy devices may not pair with a non-low energy Bluetooth version adapter.)
Amazon has a number of USB Bluetooth adapters that can be left in a USB port. One example: https://www.amazon.com/Plugable-Bluetooth-Adapter-Compatible-Raspberry/dp/B009ZIILLI .
I hope this helps.
(USB 2.0 power only ports need two wires connected. There are 4 for power + data.)
2answers
My asus X553M laptop Windows 10 X6 used to connect with my external portable jbl bluetooth speaker but not more. I'm not sure if there is a jbl driver that I am suppose to download? Any advice please?
unpair jbl speaker in windows 10
then put jbl speaker into pairing mode
then on windows 10 pair speaker in bluetooth settings
then
test speaker to see / hear if it now works
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
Looking for the operating manual for the above model
[PDF]IBC233B Bluetooth Boombox - MCM Electronics
www.mcmelectronics.com/content/ProductData/Manuals/50-9770.pdf
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful ...
[PDF]Bluetooth Portable Boombox
static.bhphotovideo.com/lit_files/113971.pdf
4. Getting Started. Box Content. • 1x Bluetooth Speaker. • 1x USB Charging Cable. • 1x 3.5mm Audio Cable. • 1x Power Adapter. • 1x User Manual ...
[PDF]Boombox - Logitech
www.logitech.com/assets/.../ue-boombox-quick-start-guide.pdf
LogitechBoombox. Wireless Bluetooth® Speaker. Setup Guide. On your device ... Tap UEBoombox in the list of nearby. Bluetooth ... community of knowledgeable users.
[PDF]Getting started with Logitech® Mini Boombox
www.logitech.com/assets/42627/mini-boombox-qsg.pdf
LogitechAll other trademarks are the property of their respective owners. Logitech assumes no responsibility for any errors that may appear in this manual. ... When "Mini Boombox" appears on the device list of your Bluetooth device, select the.
How do I charge a HMDX Bluetooth speaker
Unit should have come with a usb cable. If it did not, look at what type of connector is on the speaker,(mini usb), or take the unit to your local electronics store (Radio Shack) and have them help you find the proper cable or power supply, you should be able to plug your speaker into the USB port on your computer which will then charge the batteries (if they are recharable)
1helpful
I installed the Asus mini Bluetooth USB - BT211 and I see the icon Local Area Connection - A network cable is unplugged . When I go to the Bluetooth Suit and click on the configuration task that IE fails...
bluetooth does not connect to the internet, it connects to other bluetooth devices such as bluetooth mobile phones.
the network cable shows unplugged if there is no cable plugged into it and going into your internet router
Top Jabra Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
