Question about Palm Vx Handheld
Screen orientation My PalmVx has lost its screen orientation so that I cannot get the system to respond to touching the screen. Even pressing the restart button on th eback only takes me back to the set up screen that I can't access becasue the screen isn;t working - any tips gratefully received!
Posted by musketeer on
Anonymous
    Scholar:
  • 46 Answers
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Vx.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Posted on Nov 09, 2007
Paper white will not respond to touch.
always like to refer to Amazon help whenever possible. I copied their directions for this. Even if your's is not 5th gen it will work. You can also check specific info for your model by logging into Amazon.com Click help, then device help, click on you device and look through the info available.
Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation).
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart. Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Nov 29, 2016 | Amazon Kindle Paperwhite
My I pad is frozen, how do I get it unfrozen
Hold the button on the back edge near the back camera lense for about ten seconds.
Sep 22, 2014 | Apple iPad 2
Vtech mobigo 2 the screen keeps flashing it wont even turn off will not respond to nothing
try this: take the cartridge from both compartments. take out the cartridge. press the on button for 30 seconds. place the batteries back into the toy. try turning it on.
May 09, 2014 | Vtech MobiGo 2 Touch Learning System -...
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
My touch screen on my lg rumor touch phone by sprint stopped working so it doesn't respond yet i can use my keyboard and stuff like making calls and all that. i cant send any messages tho... is th
it's not a battery problem you have please. something has gone wrong with the touchscreen itself and needs to be quickly checked out. if you have an LG service center close to where you work, or live then you can turn it in there. you must be prepared to part with some cash too. they will diagnose the problem easily and even go ahead to get things sorted out with your touch phone.
May 23, 2012 | LG Rumor Touch
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Hi... I have a leapster which we purchased on march, 2008.Recently, the screen doesnot seem to respond for the stylus. but the button works well. what can we do to fix it? [i live in indonesia]
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Jan 23, 2009 | Leapster Learning System
Hot Synch an existing PalmVx data to a replacement palmVx
HI,
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync2.gif. It should clear up your problem. Best wishes.
Dec 12, 2008 | Palm Vx Handheld
Touch screen do not respond
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities. after installing a software i had a hard reset, after that my tuch screen did not work.please help meeeeeeeeeeee ! !
Jul 30, 2008 | i-mate JAM Pocket PC
Screen orientation
Nov 08, 2007 | Computers & Internet
Palm Vx Handheld Logo
111 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
