When I turn the camera on, the screen lights up for about 2 seconds then shuts off, every time. The lens is out and will not retract. I have recharged battery. Camera was purchased 12/08.
Did you drop your camera? If yes you either damaged the lense mechanical parts. If some dust or small particle are on the side of the lense, it may prevent the lense from opening up. If the lense opens up and down a little bite try to pull it out by have very softely. If it opened fully, clean up the outside of the lense and turn your camera a few times. If it does not have a mechanical problem, it should be back to normal. If above did not help, the lense has to be taken out and inspect for broken or damaged parts and clean it and put it back on the camera.
Good Luck!!!!
Mine was also doing that. Turn off your camera and take out the battery. Than put it right back in and turn it on. It works for me. Hope I could help! :)
-Amy
