My toshiba model no 42av500a im wathcking a show the screen goes blank but it dosen't tuen off untill i turn it off and turnit on again then i have picture again
I had the same problem. Let it run that way for about 5-10 minutes, it should show a menu, choose START WINDOWS NORMALLY.
It will take some more time to boot, be patient.
Once you start it, do the clean up, virus check and delete everything you don't it. That worked for me.
If this helps, please rate.
Thank you
means you prolly have something wrong in the tv with the actual board or chip in your tv. im not fimiliar with your model but i have a panasonic viera and it wouldnt tuen on shortly after and they said i had to send it in for repair
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
