Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Can't connect I have a motoola tracfone model#w376g, and a jabra vbt2050 headset. Can't figure out howto make this work
Posted by judyart1 on
  • judyart1 Jun 10, 2009
    tried your instructions, but it didn't work
Ryan Amontos
    Scholar:
  • 60 Answers
In your Jabra bluetooth headset, press and hold the button in the headset until you see BLUE flashing light. Once the light is flashing in the Jabra, go to your Motorola phone and search for any Bluetooth device in range. when the Jabra shows up, select the Jabra and put in the pin code for the headset "its either 0000 or 1234)
Cheers!
Posted on Jun 10, 2009
  •  Nguyen Do Van Huy
    Nguyen Do Van Huy Mar 14, 2012
    just press 10 seconds at the long-white button on the back of Jabra, you will see the ble flashing light. Turn on "bluetooth" function" on your phone. .., new pair....set connection. Enjoy.
Trying to pair my Jabra VBT2050 to my motorola. The passkey 00000 isn't working
you can only use one digit number not four digit..to detect the bluetoot headset
Sep 30, 2010 | Jabra BT350 Bluetooth Headset Headset
HK-760 Bluetooth dongle, pairs with my HP computer but after inserting the passkey, the computer starts searching for the peripheral device drivers without which a connection between my jabra VBT2050...
This device, according to the Jabra website, is intended only for phones, not PC's. The PC is searching for a driver in order to know how to communicate with the device. Since the VBT2050 does not have the necessary software contained within itself, the PC starts searching for device drivers. There are none that I could find on the Jabra website, so I don't think it is intended to be used with a PC.
Feb 20, 2010 | Adapters.com Bluetooth USB Adapater, USB...
Vbt2050 jabra codefor blackberry bluetooth
Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 27, 2009 | Jabra BT5010 Bluetooth Headset Wireless...
Is the jabra VBT2050 compatable with the blackberry storm?
should be . all Bluetooth devices should be compatible i believe.
Apr 26, 2009 | Jabra BT350 Bluetooth Headset Headset
Problem pairing my Jabra vbt 2050 with my blackberry storm
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
Mar 04, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra VBT2050
The above solution only lacks one small item. Part of the pairing procedure is to hold the on/off button for the recommended 5 seconds to power up, but the light will NOT become constant until you hold both the power button AND the round center button on together until the light remains constant. Then you can pair the two devices.
Jan 27, 2009 | Jabra BT250 Consumer Headset
Jabra VBT2050 Not detecting
On The Blue Tooth You Have To Hold The On Off Till The Light Flash's Blue Red Over And Over Then Search For It On Your Phone.
Once You Find It It Will Be Recognized For Now On. Just Hit The Button On The Blue Tooth One More Time To Stop The Sync Mode.
Jan 19, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra VBT2050 headset won't pair with blackjack II
ARE U FOLLOWING THE CORRECT PAIRING PROCEDURE
pls follow this
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth headset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will come up like JABRA VBT2050 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya for this if it helped
Jan 13, 2009 | Motorola Mobility H350 Wireless Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have [email protected] service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
541 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Marvin
Marvin
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
