Question about Denon AVR-E400
Protection mode Amp is stuck in protection mode
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 19, 2011 | Harman Kardon Audio Players & Recorders
Stuck in protection mode tried everything voltage good wires good ground good open/close button dosen,t help me at all love amp please help
everything you've tryed is useless(with respect) because amp has shorted output transistors one or more and amp is in protection mode to protect your amp from further damage.take it to repair shop or try to locate blown transistor yourself.good luck
Dec 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
Autotek XS-900.4 stuck in protect mode
Hi.
The amp does not go on protection only because of wiring or power source problem , but also and mainly when there is an internal fault.
Protection is started whenever an out-of range voltage value is detected from the controller circuit.
Protection can be triggered from a burnt final IC or from a speaker wiring problem.
Since you have ruled out speake, wiring and power source problems, then this Amp is probably defective
If the Amp works fine on a different vehicle, then protection mode may start either because speakers impedance is not within Amp specs, or because the amp has a too big power draw. In this last case the problem is fixed installing a capacitor on the Amp 12V line.
Regards.
Ginko.
Jun 06, 2010 | Autotek XS-900.4 Car Audio Amplifier
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
Amp stuck in protection mode
Most if not all modern amps contain protection circuits that continually look at the output and shutdown the amp when a problem is detected. This can be as simple as a speaker wire that has moved and is crossed or more complex like the internal amp stage containing failed parts. Disconnect the speaker wires and power cycle the amp. If the amp remains in protect mode, there is a problem with the final stage of the amp. Without having the make and model, I can not provide any details at this time.
Please try the unit without the speakers connected and update this with the results along with the make and model. Armed with that info, I should be able to post some information about possible fixes along with their costs.
Dan
May 03, 2009 | Alpine Audio Players & Recorders
DUB 2502 550WATT
check you rca in put into the am with out spkr wire connect to amp if protection light still on amp is damage
May 25, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Kicker amp
if you amp is in the PROTECTION MODE its means that there some defective part , like for example the main ICs or TRANSISTORS output might be defective , and thats why its on the PROTECTION MODE , needs to be taken to a expert technician for repair.
Apr 16, 2008 | Kicker DX350 Car Audio Amplifier
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
Denon AVR-E400 Logo
111 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
