Question about Samsung SyncMaster 191T 19" Flat Panel LCD Monitor
Samsung 191T Blank
I have used a Samsung SyncMaster 191T, today it has gone completeley black. I cannot get anything displayed on the screen. I cannot even get the Menu button to display anything. the Leds A and B changes green to off, and the power led flash green, amber and off. Please help me. Thanks.
Posted by Victor Delia on
  • 1 more comment
  • Victor Delia
    Victor Delia Jun 12, 2009
    I solved it, It was an inverter PCB problem, some power supply was not working and I fix it.
  • Victor Delia
    Victor Delia Jul 03, 2009
    Hi FixinFax,
    I understand why you are angry with my evaluation, let me explain to you:
    I thought you´d let me know where take measures and you did not give me this advice. Giving to you more details of the solution, I found an SMD open fuse ¨FTxxx¨ (I´m not sure about the last numbers 007 or 009) that was on the Mainboard, working like thermal fuse protection for 5 volts from Mainboard to Inverter PCB, so the problem was in the inverter module but in the Mainboard side, as consequence the Inverter was not working at all. I changed this SMD fuse and that’s it.
    ¨You need a fluorescent back light and inverter kit. Available on eBay.¨
    Changing the PCB inverter or backlight would not solve the problem, but for sure wasted money, so as conclusion, your advice was not the good one.
    Sorry FixinFax but you still have too much to learn, please do it for FREE and learn.
  • Victor Delia
    Hello FixinFax, I understand why you are angry with my evaluation, let me explain to you:
    I thought you´d let me know where to take measures and you did not give me this advice. Giving to you more details of the solution, I found an SMD open fuse ¨FTxxx¨ (I´m not sure about the last numbers 007 or 009) that was on the Mainboard, working like thermal fuse protection for 5 volts from Mainboard to Inverter PCB, so the problem was in the inverter module but in the Mainboard side, as consequence the Inverter was not working at all. I changed this SMD fuse and that?s it.
    I´m sorry FixinFax
Leroy Elliott
    President:
  • 3,085 Answers
Posted on Jun 11, 2009
  • Leroy Elliott
    Leroy Elliott Jul 02, 2009
    I told you it was a bad inverter, Why the NOT HELPFUL rating?
    For some reason I do this for FREE!!!
The monitor is a Samsung SyncMaster 191T. My cat laid down on the keyboard today and now I am looking at an upside down screen. Can you help me out?
If you are in Windows XP, you can use the following key combination:
CRTL + ALT + up arrow
I am not sure if this combination works in Windows 7.
Good luck.
Jul 25, 2011 | Samsung SyncMaster 191T 19" Flat Panel LCD...
I think I might have fried my Samsung SyncMaster 191T, by plugging/unplugging a dvi cable while the power was on (on both the computer and the monitor). Right now, when I enable the display using the...
Unlikely unless you discharged a large static shock into the connector as you were doing this. I have never seen a monitor or computer video port damaged by connecting the cable while power is on.
Try unplugging the power cable to the monitor for 10min or more and then reconnect and see if it starts to work.
Mar 12, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
You have either a bad inverter board or burned out backlight fluorescent bulb. Very common on this monitor.
Dec 20, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
SAMSUNG SYNCMASTER 191T PLUS
I have the same problem. Have you found a solution?
Aug 24, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Sounds like the invertor board in the monitor is bad or the LCD screen has had it and needs replacing.
Jun 04, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung SyncMaster 191T 19" Flat Panel LCD Monitor Logo
889 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
