Question about Stanley Professional Backpack Poly 4-Gallon Sprayer #61804
Stanley 61804 does not "pump up" (compress air) ?
Does it need cleaning? Where can I find a diagram?
JIM
Posted by jimornancypr on
Anonymous
Stanley backpack sprayer top is stuck....... how do I get it off?
Hi Chris:
Seems a bit extreme to consider using the 12 gauge. I've found that a .22 works quite well. (Humour)
Hint! Pressurized tanks must have the pressure relieved BEFORE the lid can be removed.
If the lid has been over tightened or has stuck, you'll need to get more leverage to unscrew it. Sometimes a rag wrapped around it is all it takes.
You can also try pouring hot water over the cap. Lay the tank flat so the rim of the cap gets the heat. Wrap an old towel around it first so it gets a good hot soak.
Should come off without the artillery.
Cheers
Mar 19, 2016 | Stanley Professional Backpack Poly...
The air compressor will not inflate tires any more.
The Air Comprressor has rubber seals inside that do eventually go bad. Since the pump seal is broken or weakened the air cannot be compressed
Jan 22, 2016 | STA-J5C09 500 Amp Jump Starter w/ 120V AC...
Need to clean and don't know how to take apart
The fan uses security fasteners to prevent dis-assembly. To clean the fan, disconnect power from fan and use compressed air to remove dust.
Jan 05, 2014 | Lasko 655702 Stanley Blower Floor / Box...
I have a Stanley Bostitch CAP2000P-OF Air Compressor. It runs constantly and won't reach the shutoff pressure. It will build some pressure. When I turn it off, I dont hear any leaks.
Jim:
There is a leak somewhere... Use a soapy solution at the air tube from the compressor head to the tank (both ends) and at all air hose connections. The bubbles will tell you where the leak is and you can repair the connections from there...
Aug 17, 2013 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Parts sprayer stanley
I would like the answer yo that question
May 10, 2013 | Stanley Professional Backpack Poly...
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Sep 09, 2011 | Stanley Professional Backpack Poly...
Instruction,use,care manual not enclosed in box
call the 1-800 #
The manual is not available online.......Sorry
Feb 14, 2011 | Stanley Professional Backpack Poly...
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE JUST POPS STRAIGHT DOWN EVERY TIME i TRY TO PUMP IT. ONLY USED 3 X. wHATS THE PROBLEM ???
the darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Oct 29, 2009 | Stanley Professional Backpack Poly...
The spray unit bent and broke...
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Aug 18, 2009 | Stanley Professional Backpack Poly...
Stanley Professional Backpack Poly 4-Gallon Sprayer #61804 Logo
1,412 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
