Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
(((((Help))))) Power On problem!!!!!!!!!!!!!!!!
Hello. I recently inherted a RCA D52W20. When the lady gave it to me she told me that the tv turns on but it takes a minute. So I took the tv home powered it on and nothing happen except for the power light blinking for 10 seconds...no picture or power up noise. NOTHING! It something wrong with the power supply or are one of the tubes bad? I opened it up but I didn't see anything wrong. PLEASE HELP ME!  : (
Posted by noble717 on
  • Anonymous Nov 15, 2007
    tv comes on then goes off
Vista Electronics
    Genius:
  • 1,694 Answers
Check ac fuse with a meter and make sure it's solid in the clips
that hold it.Then check power supply voltages.Check horiz
output transistor.Check PCB for bad solder connects....T.
Posted on Nov 02, 2007
  • Vista Electronics Nov 18, 2007
    Pull main PCB = pull little sister PCB that loosely fits on one
    connector = solder connector pins, reassemble,test...T.
Anonymous
Mine has the same problem.  No solution yet.  Hope you get an answer that is an easy fix.
Posted on Oct 31, 2007
RCA projection, no power, no sound. recently moved.
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have the same issue with the turning OFF/ON. Help!!!
The tv power IC inverter board it dead.
The repair man will cost u $575 part & labor,it up to u the tv worth the repair or not.
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button to tv
i have a friend who has this tv and the same problem. i called a repair shop abd i was told it is the high voltage converter. $400 to pick up drop off and repair.
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV won't turn on!
On the deflection board there is 3 capacitors cp150 2200uf 16v if puffed up on top it is bad so then replace other 2 capacitors as well 220uf 35v. cp114 cp120
Feb 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 not working
take the repair money and buy another tv.it would be easier and youd start out with a new tv ive seen display models at walmart for about 700.00
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
it is the power supply no doubt whatsoever
Aug 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
Who ever told you this was right the TV has a HV problem and that is why it is shutting down. I would suggest that you get one of the shops on FixYa.com to take a look at the set for you. I have worked on a lot of these sets and I can tell you that it will not be cheap.
Sep 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
