Magic Chef CGR3725ADS Gas Kitchen Range Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cgr3765adc, during bake mode upper burner does not ignite, gas smell. upper burner does ignite during broiler mode however. this problem seems to be in control module perhaps, not with igniter or burner...
Anonymous
Level 2:
  • Expert 375 Answers
  • Posted on Jul 15, 2010
Anonymous
Expert
Level 2:
Answers
375
Questions
0
Helped
141840
Points
888
In bake mode only the bottom burner will ignite. The gas smell could be caused by improper adjustment of the air intake on the bake (bottom) burner or something (foil) covering the holes in the oven cavity floor.
Kenmore model 66575775890 oven. broiler and bake burners don't work. the igniters do work, they both glow VERY bright and hot
Hello Malibro,
You converted it to LPG. Did you also convert the oven nozzles?.
Because they need to be converted too.
Kind regards, Dik
1helpful
Baking oven won't ignite, broiler element works,
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
5helpful
Oven won't heat up
Gas oven does not light
I called the service where the item was purchased.
You were no help at all
5helpful
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
1helpful
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 • Ovens
FGF374 - Broiler and Bake does not stay on
The flame sensor has to prove the flame to stay lit. When it fails, the valve closes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Oven Burner turns off during preheat
Mike, I think your problem is in the ignitor itself. Turn the gas off and see how many amps it's drawing during the bake mode. It needs between 3.2 and 3.6 amps to keep that valve open. Then ohm out the temperature probe, appox 1132ohms at room temp. You can see if your electronic control will go into a quick test by pressing and holding the cancel and broil buttons together for 3 seconds. First kill the power to the range and power back up before entering. When quick test appears you can check the bake relay by pressing bake. The relay should activate and 1 should be displayed. Same thing for convection bake except the fan should run too. Catriver...post back.
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
