Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi Aquapulse De67445 Power on okay but programme buttons do not work and will not lih
Null
Posted by simobrad on
5 Related Answers
Marty marty
  • 883 Answers
SOURCE: Zanussi Aquapulse DE6544 not emptying
find the power source (usually at the circuit breaker panel)-then turn the breaker for the dishwasher off and return to on after 10 minutes and try restarting.
Posted on May 27, 2007
Anonymous
  • 209 Answers
SOURCE: dishwasher zanussi aquapulse
this sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Posted on Sep 19, 2007
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: is my zanussi aquapulse de
It is more than likely hot water fed. You can trace the line probably to under your kitchen sink and see where the line follows up to your hot/cold on your sink. There would be then another line coming off the hot which would lead to your dishwasher.
Posted on Jan 17, 2009
Anonymous
SOURCE: Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Posted on Sep 25, 2010
dave wilde
SOURCE: The Zanussi Aquapulse (de 6965) Fault Code AL3.
Eureka! thank you FixYa. My Zannusi de6965 was failing to heat up andf finish the programe and showing Al3 read a number of your contributers and after stripping down the front of the DISH WASHER found my way into the main circuit board and there they were 2 two DRY JOINTS ( where the blue and orange wires connect) cleaned and re-soldered then re- assembled and tested.... Eureka! it worked just fine.Remember to take care when disconnecting the internal wiring from the circuit board. I colour marked each connector block and made a drawing. Thanks again hope this helps.
Posted on Jan 02, 2012
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My Zanussi aquapulse de 6654 will not start. Only the on/off switch light lights.
Hi, I have a zanussi de6965 had the same problem the only indicator light that works is the on-off button.I had a problem some years ago with my machine would not work and showed L3 as the fault as I remember. I was advised to switch off all power isolate from the wall is best(pull the plug out of the socket) I removed the front casing held along the top and down the inside by a number of small screws. You need to leave the two bottom screws in(one each side) Wiggle free the top half of the display panel to acess the box holding the PCB board.it's very fiddly you will need a sheet of paper and a pen to make a noet of the connecting sequence of the wires ( Mark the blocks of wires with numbers... when replacing everthing this should eliminate any problems) Remove the PCB board from its casing and turn over to expose the back. At the bottom left hand side I discovered two dry joints, I needed a magnifing glass to check all the joints just incase. The faulty joints were a little discoloured blackened slightly. Solution...I cleaned, fluxed and re-soldered the joints. When re-assembled all the parts. It will help when dismantling to keep a note of the number and size of the screws and where they were removed from.
My dishwasher is now working again. hope this helps.
Sep 23, 2011 | Zanussi 24 in. DE6965 Built-in Dishwasher
hi
Oct 07, 2009 | Electrolux Dishwashers
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Is my zanussi aquapulse de 4744 dw hot or cold water fed ?
Jan 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
Zanussi WJS1265 start button problem
I have had this problem which was caused by a mismatch between the power supply
socket and the 13amp plug. by changing either you can see if you get a result..what was happening was as soon as any current was drawn as the machine tried to start the high resistant contact causes the voltage to fall and the programmer stops . The same effect can occur as the heating cycle starts. a good quality plug may be the answer,
Oct 12, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Dishwasher zanussi aquapulse
Sep 19, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Stopped Working
The problem is with the PCB, this is the board behind the buttons, you can buy this for £120 or you can get it fixed by QEA for about £45 link below. I am not an engineer but I replaced mine in 10 minutes.
http://www.qualityelectronicrepairs.co.uk/lists/laundrymodels-zanussi_1.html
Sep 25, 2006 | Zanussi 24 in. DE6744S Free-standing...
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
181 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
