Question about Sony KP-51HW40 51" Rear Projection Television
Colors not matched
My tv is showing a shadow with the colors overlapping. is there a way to align the colors so that i can get a clear picture, like a horizontal/vertical adjustment?
Posted by Linwood on
  • satbrar Nov 23, 2007
    My Sony Rear Projection Television makes curb in top and bottom and colors red and out of align. How to fix it.
Vista Electronics
    Genius:
  • 1,694 Answers
Yes,there are convergence alignment adjustments, to be adjusted
by a technician after set is repaired.Replace STK392-560 IC's,then
check alignment..........T.
Posted on Oct 30, 2007
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
228 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
