Screeching noise coming from rear wheel when car in motion
SOURCE: High Pitch Noise in 2000 Jeep Grand Cherokee limited
Check your power steering fluid level, and system for leaks. May be a bad p/s pump as well. Hope this helps
SOURCE: Noise coming from rear hub after replacing various fluids
did u use honda fluid and honda friction modifier if not diff will make funny noises worse when turning at a slower pace
SOURCE: high pitched humming noise from rear near side
did they check the other wheel bearings? some time a wheel bearing noise will travel and sound some place different.
SOURCE: 1984 jaguar xj6
Hello, I have seen many differentials go bad on this model but you saying that the noise went away after you sprayed it with water doesn't make sense. If you want to check the wheel bearings, jack up the car and check the movement of your wheels by grabbing the top of the tire with one hand and the bottom of the tire with other and see if there is too much movement. If there is too much movement, then you need to replace the wheel bearings. (big job)
You also need to check the brake calipers to see if they are sticking. You can take a large screw driver and pry back the pads. They should move back with a little effort. If not, maybe the calipers are sticking.
I hope this helps.
CYA, Gator241
SOURCE: high pitch noise coming from rear of my van
Hi, it could be the fuel pump humming, the fourth gen seems to be having problem with it during hot weather. Since it is right above the fuel tank, it might be confused for a noise near the exhaust..
Take care
Hi david simpson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Hi. Need more information regarding fault and vehicle type.
