I need to install card kx-te82494 to bpx kx-tes824 v 3-0-4
I suggest you ask for remote support from www.wanetelecoms.com
Otherwise, have you enabled the card and your Telephone Service Provider supports Caller ID?
Jack 01 Press prog *#1234 speaker
Press 414 and change CO-1 from NORMALHELP NUMBER +1 833 272 0777 to DIL and Enter Jack 01 for Reception or whatever Jack is connected your to preferred answer point
Do the same for each CO Trunk line. They could be different answer points or same
Auto Save
FOR NIGHT TIME
USE PROG 415
Press 414 and change CO-1 from NORMAL to DIL and Enter Jack 01 for Reception or whatever Jack is connected your to preferred answer point
Auto Save
FOR NIGHT TIME
USE PROG 415
HERBERT STOLZ
PRIDE SOLUTIONS
FIJI ISKANDS
[email protected]
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
SOURCE: manual for Panasonic model KX-A143BXW
I have Panasonic model KX-A143BXW phone.
I want to increase the volume.
How can I do it. Thanks
SOURCE: KX-T7730 programming manual
i have 10 extentions but my call ring to all extentions. but the ring to one extentions 101 only plz tell me
