Question about Akai LCT3201TD 32 in. LCD Television
Akai power supply e7802-005008 lct 3201td
I need this akai power supply repaired how much do you charge. heres my email address [email protected]
Jaime Hernandez
  • 2,337 Answers
I can repair your power supply for $89.00 USD that includes parts labour and shipping it back via Canada post. Write to [email protected] for more info.
Posted on Jun 15, 2009
Problem with akai lct 2016
you can buy the new power supply on ebay for less then $20
Aug 28, 2009 | Akai LCT2060 Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Black screen has sound akia lct 3201td
hi you must contact akai and let them know your problem if you had your tv less than a year than you are covered
Jan 10, 2009 | Akai LCT3201TD 32 in. LCD Television
I have Akai 37" LCT TV. When I turn it on, no picture is getting displayed.
I NEED A INSTRUCTION MAUAL FOR THIS Akai LCT3701AD 37 inch Flat Panel LCD HDTV with Built-In DVD Player, ATSC Tuner and HDMI THANKS BLUE
Dec 17, 2008 | Akai LCT3701AD 37 in. LCD Television
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
Jul 08, 2008 | Akai LCT2701TD Television
NEED AN OWNERS MANUAL FOR AKAI LCT2060 My Tv.not have power
hola nesecito el modelo del boar el tv es akai lct 2060
Jun 07, 2008 | Akai LCT2060 Television
Akai LCT 2662 will not turn on
I'm surprise to see the repair shop telling you there nothing they can do.
The power supply can be fix if you take the time to troubleshoot it. However this is not a DIY project.
The failure is in the capacitors that are bulging out of the top or bottom. Quite visibly defective.
4- 3300uf @35V
8- 2200uf @25V
7- 1000uf @10V
1- 1000uf @6.3V
3- 100uf @25V
Feb 27, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Akai LCT3201TD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Paul Bade
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
