Question about NorStar M7310 Corded Phone
Our office phone only rings at the front phone, how do we set it up to go to another room's phone before going to voicemail?
Posted by shelly_a_ren on
Anonymous
You need to get into admin programming and go into lines/trunks, and make them appear and ring. If you have no idea what I am talking about, then I would call someone in to program the system, as you can screw everything up on your system....
Posted on Jun 10, 2009
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Phone only rings twice then goes to voicemail. How do I change settings to allow longer before going to voicemail?
You need to contact your carrier, ask customer service if they will change the ring time. The number of rings before vaoicemail is not controlled by the phone it is set at the cell phone switching office so they have to do it. Some carriers will some won't.
Good luck,
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 10, 2009 | RIM BlackBerry Pearl 8100
Nortel T7316E Voicemail
It sounds like both phones are set to ring on incoming calls and both phones are set to call forward to voice mail box with the same amount of rings . you should turn off the ringing for both phones that way it will not jump between the to mail boxes . now when a call is trans it will go to the box .
Mar 24, 2009 | NorStar T7316E Corded Phone
Unanswered calls will not go to voicemail
Ok, do you know how to get into system programming?
If you do:
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail
-> get into programming
-> TERMINALS&SETS enter and put in the extn that is giving you issues
-> then under CAPABILITIES look for FWD NO ANSWER and put in the DN of the voicemail you saw with the Feature 985
-> hit next for the number of rings you want it to ring before going to voicemail
-> hit next and you can now RLS to back out of programming.
Voila, that set will now goto voicemail.
Mar 10, 2009 | NorStar Lands Phones
Trying to change number of rings before voicemail
By default individual coverage is set to 45 seconds. Ask your phone vendor to reduce it.
Feb 20, 2009 | Avaya 5400 Series 5410 Phone
Setting how many times the phone rings before going to voicemail
ever think about keeping your phone close at hand and not in a different room than you are in .
Jan 20, 2018 | Nokia 1600 Cellular Phone
Rings before KX-T7736 goes to voicemail
This is just the quick answer and may not be exact. System program 203 is the intercept time. It's probably set by default to 40 seconds. A ring cycle is about 6 seconds. Try adjusting that down to, say, 20 seconds and see if that works. I have your exact setup in my office, but I'm not in my office for the rest of today. I may get a chance to play with the timing on Saturday.
Carl
Nov 06, 2008 | Panasonic KX-T7736 Corded Phone (KXT7736)
NorStar M7310 Corded Phone Logo
99 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
