Philips CDR765 2-Disc CD Recorder Logo
Question about Philips CDR765 2-Disc CD Recorder
Finding cds that work with it - Philips CDR765 2-Disc CD Recorder
Cds
is it old? mines the same way, its a bad lense, but your could also be drivers that arnt updated, go to start -type computer management -click on drivers -find your driver and right click it -update. hope that works!
Am in process tranferring vinyl to cd using sony compact disc recorder and not computer,ran out of audio discs last week purchased some verbatim discs high speed rw but will not work on my machine can you...
Hi raymackie265
You are right , don't use cds for computer ( cdroms ) but well audio cds . Pay attention to this point when purchasing new stuff . Regarding the issue with cd-Rw , it's a compatibility issue with your Sony device and you need to check if the recorder will accept CD-RWs . If yes ( and it should be yes ) , try to find lower speed discs but you need to find audio cds . I ' m using a Pioneer recorder and it works fine with any kind of audio cds , not with cdroms .
Best regards ,
fanaudi .
My cd rom drive on my emachines wont burn any audio cds but it plays audio cds. when i go to burn a cd it says connect a burner. but my burner is built in to the drive that plays the cds
Could be a missing driver file. Or the plug between the 2 could be undone internally. Or the "Properties" settings could be unchecked.
I had this same problem w/ mine. Took me 4 months to figure it out. Got it working again but couldnt play audio cds, only dvds.
Go under control panel to hardware & find out exactly the name of the maker of the drive. It should be in there.
Search that maker ie ~ Philips CD Rom with Sonic DLA burning software.
I got pretty lucky finding info specifically for EMachine. It's a generic computer so shouldnt have any problem finding info about the drive & the software. Perhaps even look for Updates. This could help also.
Having trouble strating car, no power
if its turning over but no spark it is more than likely the electronic capacitor discharge system cds unit which depending on year model cannot be repaired and replacement are expensive and hard to find if the wiring on the distributor touches anything metal with ignition on its shorts out the cds unit they are easy to replace only one wiring plug finding one at less than 400.00 second hand is another thing if buying a second hand cds unit insure that it is working before handing over any money
Drive E wont read media
You need to replace the optical drive as it is no longer working.
Printing CDs with Canon Pixma MP610
I want to print onto cds but cannot find any instructions for a canon pixma mp600
Recording with tdk da-3826
Data cds will not work with this recorder.
You must use music or digital audio cd's when recording!
2answers
CDs not playing
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. If that seems intact, (and you feel comfortable doing it) check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
If that doesn't work then have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.
Again go to my computer, to find properties/hardware/device- highlight the drive, right click and refresh or scan for hardware changes.
If its found your device works properly if not found please check when is your drive’s gate open to push the open button?
If yes please shutdown your pc and check your drive data cable.
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Top Philips Audio Players & Recorders Experts
David Shaub
Marvin
Marvin
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
