Microwave Ovens Logo
Anonymous Posted on Jun 10, 2009
MICROWAVE OVEN NOT HEATING UP FOOD
My microwave,combination oven is not heating up my food,turntable and light both working.The grill appears to be working as well.
Anonymous
Level 2:
  • Expert 97 Answers
  • Posted on Jun 10, 2009
Anonymous
Expert
Level 2:
Answers
97
Questions
0
Helped
33590
Points
307
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
My microwave oven is not heating food. Electric is fine. Turntable is working and k\light is in. Model number jvm1460. What could be the problem? Thanks
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
ll'
2helpful
2answers
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
2helpful
Space maker JVM1440WH01 sounds like it is heating, turntable turns light works, but food does not heat???
Basic Microwave Oven Troubleshooting Tips
heatman101
0'''''''''''''
1helpful
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Microwave oven does not warm food up
I have not solved my problem,I have decided to buy a new microwave rather than pay for this amount of money on a telephone advice when you have said on your site that it is free.I will also spend further amount of money, to call an electrician after your advice,so I will be better of buying a new one.
Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
yuo75
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
19helpful
2answers
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
