Question about Radio Shack Wireless Weather Forecaster
Outside unit is not working - Radio Shack Wireless Weather Forecaster
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
Outside A/C unit not working
is this 3 phase? 3 phase is diffrent from single phase
Jun 18, 2013 | Goodman CLQ36AR49 Air Conditioner
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
My blower inside my house will not come on. outside unit either
Initially, it doesn't sound like your thermostat is working.
If it has a setting to allow the blower (air mover) to be operated alone or continuously, try that.
Generally, if the inside unit (air mover) won't power up, the outside unit will not turn on for more than a couple of minutes because if the inside unit isn't working, pressure builds up in the lines going to the outside unit and an over-pressure sensor will shut it down again.
Jan 09, 2009 | Friedrich QuietMaster Electronic SS12J30D...
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Radio Shack Wireless Weather Forecaster Logo
133 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
