Question about Morphy Richards 48822 Soup Maker
Lights all flashing when i hit 'select'
Time is not appearting - all red circles are flashing when 'select' is pressed - please advise
2helpful
I have a easy share c533 and thought it had capability of the flash NOT going off - apparently i am hitting the red eye button - it looks like a flash zaggy arrow pointing down - what is this where is the...
The lightning bolt is the fill-flash symbol. Red-eye reduction is the eyeball symbol. Flash off is the lightning bolt in a circle with a slash through it. There's also an auto flash mode, represented by a lightning bolt with the letter "A".
Repeatedly press the flash button on the top of the camera to cycle through the flash modes.
Dec 11, 2010 • Cameras
3helpful
My chair was going along fine and then suddenly ground to a halt with just one red light constantly flashing at a steady rate. There is no drive! If you press the horn button a second light comes on but...
If the scooter was sitting unused for a long period of time, the gel inside the batteries may have gone solid and will not allow a full charge. You may need to replace the batteries due to the damaged cells. If you know the brand of controller that is on the scooter, you can look up the lights codes here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
How do I disconnect the flash?
Press up on the multiselector (marked with a lightning bolt). Your choices are Auto, Red-eye reduction, No flash, Forced flash, and Slow sync. Use up/down to select No flash (lightning bolt inside a circle with a slash through it) and press OK in the middle of the multiselector.
Lcd tv 19lg30 have you got the number for the remote ie.code.So i can also use my sky remote. as my tv handset no longer workes.
turn on your tv, on the sky remote press tv and then red and select at the same time, the red light should flash and then press tv then standby then tv then standby, do this until your tv turns to standby, once this has happend press select again and it should flash, this is then tuned to your tv, if not in your search engine type in sky remote codes for your make and model and then press tv red and select at same time enter the code and then select and see if that works, but the first optioon is the easiest, good luck
1helpful
My flash isnt working on my A835 camera and i have only had it for 6 months
Check the flash mode that your camera is set to. The flash modes are: Auto, Red-Eye Reduction, Forced Flash, No Flash, Slow Synchro, and Red-Eye plus Slow Synchro. You might have the flash mode set such that your camera detects that the lighting doesn't require the flash mode selected. You can try manually overriding the flash mode by pressing left on the circle function button next to the LCD view screen. If you are still unable to manually turn the flash on, try changing the shooting mode with the mode select dial on top of the camera, then if necessary repeat the flash override step mentioned above. Repeat until successful. There is also the possibility that the flash is malfunctioning, but that is less likely than a setting issue. Let me know how you make out.
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
3helpful
Photon Digital Scorecard - Golf
Press player button long time, then select with right hole button time mode (12hr or 24hr).
Press player button to select hour and then press rigth hole button to select rigth hour.
Press player button to select mn and press right hole button to select rigth mn.
When tthe clock is right time, press a last time the player button.
1helpful
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
1helpful
Hello i want to turn the auto flash off
Press the up arrow on the back of the camera - that seems to be the flash mode setting - select which flash mode you want - you have to hit the down arrow once to see the flash off option which is a picture of a flash symbol in a circle. Then press ok. The flash should now not fire.
Morphy Richards 48822 Soup Maker Logo
Top Morphy Richards Cooking Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Morphy Richards Cooking Expert? Answer questions, earn points and help others
