Question about Magic Entertech ED-9000 Mic Sing Along with 200 Songs Microphone
No voice but the music is normal
Cesar Caldito
    New Friend:
    Problem Solver:
  • 9 Answers
Microphone is disconnected from the motherboard.
Posted on Aug 30, 2016
Can hear voices but no background music/sounds?
Try turning up the brightness if you are talking about a television?
Switch on e50 and sustain pedal not holding notes
I assume you are plugging this into a ROLAND brand product as the Roland sustain uses a normally CLOSED contact while MOST other brands use NORMALLY OPEN contacts.
The Roland synths now monitor the pedal as the power is turned on and supposedly decides which contact type is used.
Remember that for MANY voices, such as piano, notes are held longer BUT they do not continue indefinitely just like the sustain on a real piano works. On a real piano the dampers are lifted, but the strings eventually stop ringing due to the losses of energy in the strings.
Some voices will be held,such as organ tones.
I don't have enough information from your post regarding what voice you are having trouble with.
I have a Onkyo TX-8222 receiver. Sound is ok for music but voices are very low. When two voices, one is very clear abd the other very low. What is the problem ?
You don't say what source(s) are affected. I'm guessing TV or Cable-TV is the problem because music with vocals has voices and you say it sounds ok. Your speakers have no clue whether a sound is a voice or music so that lets THEM out and your receiver doesn't know or care either.
In the modern multichannel world it's usually assumed your electronics are multichannel. This receiver is old-school stereo.
The Center channel is usually where voices are found but some systems (like yours) don't have a Center speaker so they have to be configured to share the Center duty with the front left and Right speakers.This isn't possible or even normally necessary in your case. WYSIWYG
http://www.retrevo.com/support/Onkyo-TX-8222-Receivers-manual/id/469ci869/t/2/
The audio coming in from 'wherever' should be correctly mixed to 2-channels at the source or you'll probably be missing something. I'd look higher up the audio food chain for where the voices are being attentuated. If a cable box is involved I'd look at its audio settings regarding stereo mix-down
Wait, I just had an inspiring thought. Centered voices being mono in nature would partially cancel out if your two speakers were out of 'phase' with each other. Bass would also suffer. Make sure your two speakers are wired identically regarding the red and black (or plus and minus) conductors. If turning the Balance control fully to one side makes bass of voices sound louder you probably have a phase mismatch. Reverse the wiring on either speaker to match the other. There is no absolute right or wrong for phasing as long as they're all the same.
1helpful
How do i set my mp3 songs as my ringtones on my Samsung GT-B3310 Corby Mate
in the settings you have phone profiles on normal select options edit go down to voice call ringtone press middle button downloaded music and choose your music good luck
Where do I download midi keyboard drivers for a technics keyboard.
Normally the drivers you load are for the MIDI interface you use, not the keyboard.
The software for the keyboards are usually either system update programs OR editors for the voices, etc. There are many music editor programs and most have some method of communicating via MIDI to external devices.
Apr 22, 2010 • Music
Olympus ds 40 can't display recorded voice folders on pc
There are a total of eight folders in the recorder that are in a tree format. Under the “Root” folder
are “Folder A” through “Folder E”, “Audible” and “Music” folders, and recorded or transferred
Language and music data from a computer can be saved as “files”. “Folder A” through “Folder E”
are voice-recording folders, so choose one of these five folders when recording on this recorder.
Up to 200 files can be saved in each folder, and up to two layers can be created within the “Music” folders.
1helpful
Hiss noise
its never normal for your phone to make sounds other than what you want it to make. try lowering the speaker volume to the lowest setting but still allow yourslf to be able to hear. check to see if its still making the sound. if so try getting your music from a diffrent source. if that also fails try voice record if its avalible on your model phone. play voice listen for the unwanted noise. reason for this is to narrow the problem . how long has the phone done this?
your phone speaker is most likely the problem seeing that even the phones own tones has a static sound.
could have blown speaker .
1helpful
How do you convert the mp3 from the olympus digital voice recorder into a .wav file. I know it requires I Tunes, but other than that I don't have a clue. I know how to convert a normal mp3, but...
I think maybe the Olympus MP3 is DRM protected so if you would like to convert the file into .wav file .the first thing you need to do is to remove drm from this file and then convert it .here,I 'd like to introduce you an all-in-one music converter.you could solve all your problem at the same time .save your time .http://www.removing-drm.com/music-converter/reference.html
Top Magic Audio Players & Recorders Experts
W.L.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
