Question about Toyota Toys
Toyota forklift muffler removal
How do you remove the weight from the rear of a toyota forklift
Brent Macumber
  • 69 Answers
Remove bolt and lift off with another fork,, MAKE SURE YOU DONT DAMAGE THE RADIATOR WITH THE LIFT FORKLIFT
Posted on Nov 26, 2014
How to remove transmission from my 96 Toyota Camry 4 cylinder
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 20, 2018 | Toyota Cars & Trucks
Need to replace rear camera with new one. Cant figure out how to take it out. Its a 2003 Toyota Estima
These are books c ontaining info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 18, 2018 | Toyota Cars & Trucks
19933 land cruiser rear window won’t go up fully
Jun 10, 2018 | Toyota LandCruiser Cars & Trucks
Timing on a 4y motor toyota forklift
images for Timing on a 4y motor toyota forklift
Timing Chain And Sprockets, Cover And Seal - AutoZone
www.autozone.com/.../Toyota.../Engine.../Timing.../_/P-0900c...
AutoZoneToyota Cressida and Van 1983-1990. REMOVAL & ... 1 Exploded view of the timingcover assembly-3Y-EC and 4Y-EC engines. Click image to see an enlarged ...
How do you set the timing for a toyota 4y engine - Fixya
www.fixya.com/cars/t9616067-set_timing_toyota_4y_engine
Jun 29, 2011 - Posted on Jun 29, 2011.
Nov 07, 2015 | Toyota Cars & Trucks
How to replace spark plugs on a 2008 Toyota Tacoma 4 cyl
Not a difficult job, but difficult to outline without photo/video aid.
Short list, using compressed air, blow out all of the junk that has collected under the intake muffler, then remove the muffler from the throttle body and airbox There are two large hoses, plus two small hoses, one on the rear (crankcase vent) and one in front. There is also a wire harness on the rear that needs to be separated.
Once removed, make sure the top of the cam cover is clean, unplug the wiring harness from the coil packs, remove the bolts (10mm socket), and pull the coil packs from the plugs. The rear plug is a bit of a pain because of the wiring harnesses, but you can carefully separate them and move them out of the way.
The Tacoma 2.7 uses Iridium plugs. Stick with the OEM Denso plugs, don\'t fall for the snake oil salesmen pushing 4 electrode or special "hot spark" designs.
Jun 07, 2014 | 2008 Toyota Tacoma
Toyota forklift
use a crane to take the weight . Undo the long mounting bolts that go through the weight .Ensure that you have sufficient lift on the crane or the weight will fall and hurt you.
Feb 21, 2014 | Cars & Trucks
How to rebuild rear shock 2003 honda crf 450
Put the bike on a stand supporting the bottom of the frame. Remove the seat and sidepanels. Loosen the clamp on the carb to airbox boot at the rear of the carb. Loosen the muffler clamp, remove muffler mounting bolts and pull muffler. Remove the 4 rear subframe bolts. Remove the rear subframe (leave airbox and rear fender assembled in it). You are now staring at a completely exposed rear shock. Remove the shock mount bolts and remove the shock. Measure the spring adjusted length for a future starting point when the spring is put back on. Loosen both spring pre-load adjuster spanner nuts all the way. Helps if you clean the dirt off the threads and use a little lube. Pull the spring towards the spanner nuts and remove the clip ring at the opposite end spring holder. that's it.
See here
May 10, 2012 | Honda Motorcycles
How do i remove the rear shock spring from my 2004 crf 250r
Feb 07, 2010 | 2005 Honda CRF 450 R
Install a gas tank in a 94 toyota corolla
Raise the car.
Loosen the fuel filler neck rubber hose clamp. Remove hose from tank. Insert tubing into tank and siphon out all fuel.
Undo the brake line bracket blots and move brake lines out of the way.
Undo the exhaust to muffler flange bolts. Exercise extra care if they appear rusted as they will shear off.
Remove rear seat and undo fuel pump cover. Undo fuel pump bolts.
Disconnect the fuel and return lines.
Support tank with a jack. Undo tank strap bolts. Remove straps.
Lower tank and remove fuel pump.
Drop tank and slide out over exhaust.
Nov 02, 2009 | 1994 Toyota Corolla
Toys Logo
959 people viewed this question
Top Toyota Toys Experts
ROB
Thomas Perkins
Thomas Perkins
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
