Question about Rowenta Commercial Garment Steamer - White
On and off petal switch not working
Using the rowenta garment steamer IS 8100, Power switch { petal} no longer working, how can i get it replaced?
Posted by coleman1658 on
Anonymous
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Posted on Jun 13, 2009
Rowenta IS 8100 not heating
Could be lots of things and these need checking through systematically starting with the power cable and working through the circuit stage-by-stage.
Other possibilities, ignoring such things as loose terminals, are thermostat, any safety devices and the heating element.
A multimeter is an essential aid in this sort of task and some familiarity with checking electrical equipment is important.
Feb 23, 2016 | Rowenta IS-8100 Commercial Garment Steamer
Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Nov 07, 2013 | Rowenta Irons
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
Dec 26, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - White Logo
1,294 people viewed this question
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
