Question about Sony Handycam DCR-TRV280 Digital Camcorder
Shows c:31:20 sp with a arrow
Sounds like the tape is unwinding
Posted by Rod Day on
How to change language
Turn on the printer.
"Ready" on panel display.
Press "Menu" key.
Press the Up or Down Arrow key to show "Language."
Press the Enter key. "Language: *German" shows on the panel display.
Press the Up or Down Arrow key to get the language you want.
Press the Enter key. "Menu" shows on the panel display.
Press the On Line key. "Ready" shows on the panel display.
May 30, 2014 | Ricoh Aficio SP C410DN Laser Printer
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Apr 27, 2012 | Sony Televison & Video
Can't get tape out. Stopped recording in middle of school play and I was unable to remove tape.
Sounds like the tape misfed during the recording and wrapped itself around the fly head and recordinghead. This happens sometimes when the internal workings of the recorder get dirty. The hard part is getting the tape out without damaging the unit. Your going to have to bring the recorder to a repair shop or crack it open yourself and from the opposite side try unwind the tape.
Oct 04, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
My Toshiba DVR670 dvd recorder/vcr combo. When I turn on the combo and have a tape in it it will display in the bottom lefthand corner the letters SP and an arrow pointing up with a line under it above the...
need to repair or replace the unit more likely the VCR belts are not tight enoughsince the advent of DVD recorders the quality of VCR components has gone way down I have 3 combo units the only one that still records is in the unit which only has a DVD player in it. and even that won't allow tracking adjustment
Dec 07, 2009 | Electronics - Others
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
Jul 14, 2009 | Sony Betacam SP Small Videocassette 30...
Rca vr626hf=tape unwinds inside after loading
You have a sticky pressure roller which can be cleaned with some alochol based cleaning liquid but first make sure the capstan motor is operational.
May 12, 2009 | RCA VR626HF VHS VCR
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
Jvc a 55u plays a movie from the store but I cant get it to tape a regular tape,it's a nice vcr and I have never seen this problem, the moves from the store are played great but when I put in my own tape...
Hi Diane,
Just downloaded the manual for your vcr it says:
1 Press menu
2 press up/down arrows to Function Set then press ok
3 press channel up/down arrows to Auto picture then press Ok or shuttle plus right arrow to set to on or off when using rental tapes set either to on or off to give the best picture
4 to return to normal press menu
For recording
1 load a cassette make sure the tab on the cassette is intact if not put some cellotape over the hole
2 set channel press up/down arrows then press enter
3 select tape speed sp/ep
4 press and hold rec and press play on remote or just press record on unit
5 to pause recording (cut out ads) press pause on remote to continue again press play
6 to stop recording just press the stop button
hope this helps and reflects in my feedback lol all the best
Jim Scott
Feb 28, 2009 | JVC HR-VP693U VCR
I somehow managed to write protect so I cannot take pictures or transfer pictures to my laptop. How can I undo this? I have an Olympus sp 700 Thanks Durriya
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Jan 10, 2009 | Olympus SP-700 Digital Camera
Sony Handycam DCR-TRV280 Digital Camcorder Logo
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
