Question about ATI RADEON X1650 Graphic Card
ATI RADEON 9000 not recognized on GA-686bx board
Hi guys, Trying to use the above graphics card in a Gigabyte GA-686bx board running a pentium II processor. The card fits no worries, but with the card plugged in, the computer won't even do self tests. It powers up, no self tests, no hard drives clunking. Tried it in all 4 slots - same result. I've just taken out an S3 card which works fine, however I really need to change it over so I can use DVI instead of VGA. Any help would be appreciated. Thanks Pete
Posted by Peter Schmidt on
kenllynch
    Sergeant:
  • 344 Answers
Ati is not compatable with the new intell boards get a NVidia card for intell boards.
Posted on Aug 19, 2014
5 Related Answers
Anonymous
  • 112 Answers
SOURCE: how to enable Crossfire with my two ati radeon x1650 graphic card
You need two pci-e slots. Put the cards in the slots. The cards connect with a crossfire bridge. Then just plug your monitor in and your ready to go. Make sure that you have the software installed and that your chipset supports crossfire. For more info click here.
Posted on Nov 19, 2008
Anonymous
  • 47 Answers
SOURCE: Graphic Card
ok.. the first thing is.. u need to either physically look at the chips / or chipset on the card.. then locate the gpu.. when this is complete enter the gpu name into google.com or .ca and add driver to the end of the search query then you should--- or this link should do nicely for windows xp http://ati.amd.com/support/driver.html
Posted on Jan 09, 2009
Anonymous
  • 375 Answers
SOURCE: blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
BACK UP :)
Posted on Jun 29, 2009
Anonymous
  • 38 Answers
SOURCE: geting motherboard vga output and ATI RADEON HD 2400 PRO graphic
no you can't
Posted on Apr 05, 2010
thinktech09
Andrew Chrostek
  • 178 Answers
SOURCE: Will My ATI RADEON 9550 Video Card Work With GTA
these are the specs you need!!
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Posted on Jun 15, 2010
7helpful
ATI Radeon 9000 (RV250) download
your driver for ATI Radeon 9000 (RV250) can be download from here :
1helpful
I have a acer x163w 13" monitor and I am trying to play call of duty 2 but keep getting the input not supported. How could I fix this problem so that I may play this game?
Call of Duty 2 Minimum System Requirements
3D hardware accelerator card required - 100% DirectX 9.0c compatible 64MB hardware accelerator video card and the latest drivers*
English version of Microsoft Windows 2000/XP
Pentium IV 1.4GHz or AMD Athlon XP 1700+ processor or higher
256MB RAM (512MB RAM recommended)
100% DirectX 9.0c compatible 16-bit sound card and latest drivers
100% Windows 2000/XP compatible mouse, keyboard and latest drivers
4.0GB of uncompressed free hard disk space (plus 600MB for Windows 2000/XP swap file)
8x speed CD-ROM or 2x DVD-ROM drive
Multi-player Requirements
Internet (TCP/IP) and LAN (TCP/IP) play supported
Internet play requires broadband connection and latest drivers
LAN play requires network interface card and latest drivers
Supported Chipsets
ATI Radeon 8500
ATI Radeon 9000
ATI Radeon 9200
ATI Radeon 9500
ATI Radeon 9600
ATI Radeon 9700
ATI Radeon 9800
ATI Radeon X300
ATI Radeon X550
ATI Radeon X600
ATI Radeon X700
ATI Radeon X800
ATI Radeon X850
nVidia GeForce 2 Ultra
All nVidia GeForce 3/Ti Series
All nVidia GeForce 4/Ti Series
All nVidia GeForce FX Series
All nVidia GeForce 6 Series
**Recommend nVidia GeForce 7 Series or higher
Do your PC support the above hardware requirements?
The most common input no support would be your graphic card is not up to the mark to play the PC games.
Is your graphics card drivers up to date to the latest?
Have you updated your DirectX to the latest version?
Hope it helps.
1helpful
I have a Gigabyte GA-81945GZME-RH motherboard that needs a new graphics card was wondering will ATI Radeon 5570 1GB PCI-E graphics card work. Thanks for any help you can give me.
The motherboard has a PCI-E slot, so the Radeon card will fit. You might need to upgrade your power supply, as a 400-watt supply is recommended on AMD's site for this card. Otherwise you shouldn't have any problems with the new card.
1helpful
Hi i got ati radeon 9000 agp lost CD!!!!!!!!
You can get the drivers for this card from http://ati.amd.com
2helpful
2answers
Graphic card for GA-8IPE1000 series
HI there.
There are loads of makers of memory and graphics cards out there to choose from.
For the ram i would recommend Corsair or Kingston, you can get this ram as a matching pair so the both run at the same speed, the best ram to get is DDR 400.
As for the graphics card, i recommend ATI radeon X1650 Pro 512MB graphics card.
These upgrades will make your machine purr like a kitten with an excellent gaming experience.
Good luck and thanks for choosing FixYa!!
2answers
ATI 256MB Radeon X550 Graphics card
r u using dvi or vga? does the monitor support dvi?
ATI RADEON X1650 Graphic Card Logo
Top ATI Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Mehandi Husain ...
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
