Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Flames don't appear
Still produces heat but we don't see the little flames shooting out. Can you help us get our little flames back?
Posted by Terri Broemm on
My geyser ignites and then it burns for about 10 seconds and then the flames go out.
There is a "flame" sensor adjacent to the burner. It looks like a little short rod. When the flame touches the little rod it senses that the burner is, in fact, producing fire and is not releasing unburned gas. The sensor will sometimes get corrosion and not sense the flame, which turns the gas off. This is an easy fix and doesn't require any parts. Take a small piece of 320 grit sandpaper and scrub the sensor rod to remove the oxidation (corrosion) until it is again bright shiny. The flame will then stay on.
Sep 05, 2018 | Heating & Cooling
My gas fireplace..I only want to see the flame. I don’t want the heat at the moment. How do I do that
????? ah gas when lit will produce flame which also produces heat with gas you cant have one without the other ----only electric can you have a flame show and no heat and visa versa
Nov 07, 2017 | Heating & Cooling
The pilot lights are shooting out flame. How donI fix?
Don't understand......pilot light IS a flame. What is the problem? Is the flame lazy and big? Then the pilot hole is dirty. don-ohio
Jan 04, 2017 | Heating & Cooling
Gas dryer runs but no heat. Took it apart cleaned all ducts and lots of years worth of dirt out of entire machine, looks brand new. Tested all components.
You did quite a bit of work. One other thing that controls the ignitor is called the flame detector. Its the black box looking thing mounted on the side of the big pipe the flame shoots into. Should be 2 wires going to it. A quick test to see if the ignitor comes on is to tie the 2 wires together. If you see the ignitor come on thats the bad part,
Jun 29, 2015 | Dryers
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
DEAN SR142GPS Flame Issue
A gas valve is actually 2 valves in one. The first is your pilot valve, when the pilot is lit, the flame heats a thermocouple or thermopile & that heat produces a millivolt signal that is sent to main gas valve( second part) & tells it that pilot is established and to open to allow main burners to light. The 3 "little flames" were coming from the orfices on the burner manifold. If you are absolutely sure you put the gas valve back in the same direction as it came out (arrow on bottom of valve pointing to the fryer/burners) & any springs or adjustment screws were not mucked with, then there is a malfunction in the gas valve. It needs to be replaced.
Jul 24, 2008 | Kitchen Appliances - Others
No heat
It can be both the heat fuse that gone or your pilot light has gone out, check to see if you see a flame while it is functioning, to do this turn on your dryer and watch in the dark so that you can actually see the flame coming on and off or check behind the little door that houses the pilot light to see if you see a flame if no flame relight, this should start your dryer producing heat again
Jun 22, 2008 | Sharp R-353 Microwave Oven
Heating & Cooling Logo
131 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Bill Johnson
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
