I want the faxes forwarded to my email address, was set up this way previously but not sure how to set it back up.
SOURCE: can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: HOW do i get my brother intellifax 2820 to time stamp the faxe
From everything that I've seen I don't see any way to tim stamp incoming faxes. Almost all fax machines should automatically time stamp outgoing faxes unless the user has removed that function for some reason. If you are getting faxes from people that don't include time stamps than the next best thing is to use the journaling feature. The 2820 can print a journal of past incoming faxes that will include timestamps of the past faxes recieved in either 6,12,24 hour or 2, 7 day intervals. The default is every 50 faxes. To change the settings:
Press Menu/Set, 2,4,2
2. Journal Period
Use Arrows to choose an interval
Press Menu/Set
Press Stop/Exit
SOURCE: Brother Intellifax 2820
most new machines have a fax block mode to eliminat unwanted faxes coming through, just reset your fax machine to factory setings and then re load your personal data , this should rectify this problem
SOURCE: How do I set the machine to receive automatic instead of manually
go to initial set up , receive mode, change it to fax only
