I have been using my Nikon Suber Coolscan 8000 ED for some time now with Vuescan. Yesterday it would not show the preview or scan. Now I can not see my scanner. I checked the firewire cable etc. Do I need to send it in somewhere to get fixed?
SOURCE: have Nikon coolscan 4000 ED
You need to install the drivers before the pc will recognize that there is a scanner connected to it. I would also suggest using the software that came with the scanner instead of just a program that you already have in your computer.
Here is a link to the users manual with the specs and software required to run the scanner correctly below. You can usually get a copy of just any software from CNET's website (www.cnet.com). Try locating the name of the software that the manual says came with your scanner and then go to CNET's website and find a trial version or free version and download then install it on your computer before connecting the scanner. You need to make sure that you do not connect the scanner before installing the drivers and/or software, so if you have it connected now remove the cable.
http://support.nikonusa.com/app/answers/detail/a_id/13227/~/super-coolscan-ls4000-ed-%2F-coolscan-iv-ed-user's-manual
Windows 7 does not run scanners the way that Windows Xp & Vista do. Your scanner may be set up correctly now before chasing down the driver and/or software. You might want to check using the method listed below before making any changes as noted above.
With XP, the scanners software would be installed on the pc before using and you would see a picture of the scanner with the name on your desktop. To scan you just double click the ICON and follow the prompts.
With Windows 7, to use your scanner you need to click on the round globe on the bottom left of your screen (the one with the flag in it) and then go to "devices and printers" and click on that too.
Find the name of your scanner and right click with your mouse on top of it to get a drop down list of choices. In that drop down list find "scan" and click on it and you will get a drop down list of choices with scanning preferences. Choose your preferences and click scan or "ok" at the bottom. Thats how you scan something in Windows 7. Maybe you were opening the software and trying to scan something that way? After the scanner scans your image, it will number it and take you to where it stores the default scans. If you double click on the document or picture in this area, it will open it in your default software. If you have your computer set to use Vue Soft, then double clicking on the picture or document after scanning it will open it in that software.
Hope this helps?
SOURCE: I have a nikon coolscan
Hello sir!
Better check first if your system was able to detect your scanner.
See if the Film Scanner is detected on the FireWire Device
Tree,
go to: Apple > About This Mac > click the More Info button
> then select FireWire in the Hardware section.
If so, then open the Image Capture
Application and see if you can select the Nikon Film Scanner?
If you can not find your scanner...Please disconnect all Firewire devices.. and leave only the film scanner connected on your system before installing the driver software.
I am on a Mac Intel running 10.7.5. Everything was working fine for the last year.
Is their somewhere I can take it or send it?
