It wont take a picture because of Error 05 or BUSY
The Error 05 means the build in flash cannot be raised.
In the moment it should pop up, something was blocking the free movement. Could be caused by the way you were holding the camera. Could be happening, while you were pressing the flash button, or when you are in the basic zone shooting mode, such as portrait, which needs the use of the flash.
Switch the camera off an then on again. Move an eventually cause of the blocking and press the shutter realise button again.
SOURCE: Canon Digital Rebel XT / EOS
In the communications option of the camera Menu, there are two options to choose from. Try changing the options. one of them works with Canon software to download images.
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
SOURCE: I'm trying to transfer my pictures from the camera
Could it be the camera battery is depleted?
