Washing Machines Logo
A
Anonymous Posted on Feb 21, 2014
Logik L712WM13 error e30
Flashes e30
Cathy Stevenson
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 07, 2014
Cathy Stevenson
Contributor
Level 1:
Answers
Questions
0
Helped
2604
Points
0
On a Logik L712WM13 E30 means there is something stuck in the door.
Logik 8kg heat pump tumble dryer error message unknown
I think it is a play on words and heat pump means it pumps heat. A heat pump in normal parlance is taking heat from a source that would be wasted, like turning a refrigeration system around and using the heat supplied from cooling, to heat an area.
https://www.currys.co.uk/products/logik-lhp8w18-8-kg-heat-pump-tumble-dryer-white-10174302.html
I would guess it has an element, and when you look at the wider view, it is a condensing dryer so the heat from the element makes steam from the clothes which is condensed by the incoming cold air, ergo, it is a heat pump.
https://www.google.com/search?q=Logik+8kg+heat+pump+tumble+dryer+heat+pump
Get your old multimeter and screwdriver out and start testing.
Dec 05, 2022 • Dryers
1helpful
2answers
Logik lhp8w22 fault - suspect E05 as dont have manual
https://currys-ssl.cdn.dixons.com/manuals/Logik%208%20kgs%20Heat%20Pump%20Tumble%20Dryer%20LHP8W22%20Manual.pdf
Dec 02, 2022 • Dryers
Need manual for logik washing machine l712 wm13
Below is the only site I have found offering a manual. I have no experience with the site listed. You might look for WOT scores (Web of Trust), or reviews of the site.
http://manualpub.com/doc/logik-l712wm13-manual
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
1helpful
6helpful
2answers
I have Logik MI1006 and it will not play a sound
Please check charger, propoblly light on charger is flashing to. If yes you have to replace charger on new one or fix the existing. ( leroyek69 )
4helpful
Zanussi washing machine zwf1437w error code e30
E30 indicates a pressure system fault. There can be several causes but the most frequent is a blockage in the system.
First thing to do is check the filter on front of machine.
Please do this and report your findings.
4helpful
2answers
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
2answers
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Top Washing Machines Experts
john h
