No Mic Bus Message/ Possible causes/ Faulty Mechanical Instrument Cluster (MIC) Module Mechanical Instrument Cluster (MIC) Module harness is open or shorted Mechanical Instrument Cluster (MIC) Module circuit poor electrical connection
You used the term "plug in my mic". I assume you mean the microsoft mic and head set. one of the best ways to check the headset and mic. is to go onto microsoft live and attempt to leave someonw a voice message. during the message you will get a message that says your mic is not working. also after you finish the voice message attempt to play if back if you do not hear anything then the problem is with your microsoft head set and attached mic. if new take if back to exchange for another one. there could possibly be something wrong with the port connection on you microsoft controller.
You can record your own greeting message (max. 2 minutes) that is played when the answering system answers a call. If you do not record a greeting message, a prerecorded greeting message is used.
1 {GREETING REC}
2 Within 10 seconds, press {GREETING
REC} again.
3 After the base unit beeps, speak clearly
about 20 cm (8 inches) away from the
MIC.
4 To stop recording, press {STOP}.
Recording your greeting message You can record your own greeting message (max. 2 minutes). If you do not record a greeting message, a prerecorded greeting message is used. 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm (8 inches) away from the MIC. 4 To stop recording, press {STOP}.
Are you at the answering machine or calling into the machine? If you are at the machine, press and hold Annc/Skip. Wait for the beep and then speak normally from about 9 inches away from the mic (just below the Play/Stop button). You will see a dash in the display. To stop recording, press Annc/Skip. The system will play back your message. (If you press and release the Annc/Skip button, it will play back the current message.)
If you are dialing in, once you are into the system, press 7 * and wait for the beep. Speak your message and then press 5. The message will play back.
message
message (2 minutes max.).
1 {GREETING REC}
clearly about 20 cm away from the
MIC.
4 Press {?} (STOP) to stop recording.
Playing back the greeting
message
Press {GREETING CHECK}.
You can also operate the answering
system by pressing dial keys on the handset
Key Operation
{^} or {V} Adjust the
receiver/speaker volume
{1} or {<} Repeat message (during playback)*1
{2} or {>} Skip message (during playback)
{4} Play new messages
{5} Play all messages
{8} Turn answering system on
{9} Stop playback*2
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
message
1 {GREETING REC}
from the MIC.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
message
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
to tell u the fact it was working a week before but now suddenly it has stopped n the message i m getting is the server is busy. please try after sometime
Try sending yourself a message and see if you hit play (after recording the message) you can hear yourself. Sometimes Ive been playing games like GRAW2 online and when I lose connection with the host or something along those lines my mic will stop working untill I reset the console.
Also, most games will have some kind of an indicator when you are on Live that show when someone is talking. Do these indicators activate at all? (usually a small volume symbol that will light up next to the persons gamertag)
