Question about H20 Bolt Flash 4G USB
When i know when my h20bolt end - H20 Bolt Flash 4G USB
I own a 2003 proton jumbuck ute and want to replace drive shafts, the outer wheel end not a problem but need to know what I have to do to release drive shafts from gearbox end. thank you for your time
most cv axles or held in the gear box /diff by a round sectioned circlip at the end of the splines in the diff
once you have the axle free of the hub and bearings use a heavy hammer on the back side of the cv joint or a heavy slide hammer attached to the end of the axle
you have to compress that circlip so that it allows the axles to slide out
May 30, 2016 | 2003 Proton Juara
I taped a TV show. But I can't fast forward to see the end part that I want to watch. It just advances to the end.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
Mar 26, 2015 | Televison & Video
I have a 94 explorer limited that has the amplified stereo in it . the #@%^$*& guy that I bought it from cut the speaker wire end (little black end) Off . Does any one know how to rewire the end b
If you get the wire assembly from the junkyard you will not have to splice anything. Then the connector will go to the correct speaker. Also you may as well take the whole thing because snipping off the ends ruins the rest of the wiring for the Salvage yard.
You might want to know if the rest of the original wires were patched anyway.
Jan 24, 2015 | 1994 Ford Explorer Limited
1998 Dodge Ram 1500 Rear End problems
Hello, well you can look at it in a few different ways. Like you stated you can get a rear end from a salvage yard and not know what you are getting, you can spend some big bucks to get a new rear end, or you can get it rebuilt. I feel getting it rebuilt will be the better option. If you get it rebuilt you will have new parts in the rear end and know what you have verses the cost of a new rear end. This of course depends on how much damage there is in the rearend. Economically I feel that having it rebuilt is the best option. I always get nervouse when putting in any used part because you don't know what you are getting. If you do get it rebuilt make sure they put in new bearings which any reputible shop should anyways.
Mar 31, 2009 | 1998 Dodge Ram 1500 4WD
I replaced the headline recently and lost the parts to attach the rear seatbelts back up, what do I use?
The bolts at the end of the seat belts should be screwed into the mounting holes in the floor, which I believe are threaded at the ends, so u shouldn't need anything at the end of the bolt. Let me know if this is not correct.
Nov 02, 2008 | 1993 Jeep Grand Cherokee
End of the speaker wire
I dont understand what you mean by what you said. What is the color of the end? What is it the end to? the end of a wire?
I think I might know what your talking about but I want to make sure we get it right the first time.
Thanks,
Lee
Jun 13, 2008 | Durabrand STS92 System
Ipod nano
you should disconnect the computer end,the Ipod end.
Mar 24, 2008 | Apple iPod nano
H20 Bolt Flash 4G USB Logo
442 people viewed this question
Top H20 Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a H20 Computer and Internet Expert? Answer questions, earn points and help others
