Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
TV come on and I can do ajustments. No picture or sound
Philips tv how to set air to cable setup
I have tv the remote has a button that says format it took me a while to figure it out hope this helps Merry Christmas
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
I try to ajust the green convergence on reference mark down ,and i can't move this line to left or right. how i can ajust the lamp to the righ or left. thank you
Ur tv 100% have a problems known as a convergence picture peoblems.The tv convergence board it is dead,if any of the colors lines R,G,B mis alignments and u will not able to auto or manually to adjust any of the R,G,B colors lines to alignments any of them up.The tv convergence board must be replace like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
1helpful
How do I change the format on the screen to fit my TV, the format is too large and the picture is getting cut off on both sides
U using the tv original remote wright?Yes.Check ur tv remote control for a button like View Mode,Aspect Ratio,Picture Zoom,P.Size.Pushes one of these buttons to ajust the tv picture screen sizes.
2answers
Picture djust
Put it in the custom mode.Put the contrast to the max.Put every things in middles may be colors for less.Now u have the desire ajustment u want?
1helpful
Have model F25190SE, old 1992 tv, Chassis CTC177AC. No signal coming in from rf connector, television all snowy. Can use the rca connections, still has very fine lines in picture. I've replaced the rf...
cristal and IC to be replaced and solderings on all grounds in the tuner unit. maybe costly for a tv of that age, for the fine lines there are 2 ajustements on the back of the tv set, one is focus and the other one is sceen, that ajustement is too high , just turn the ajustement counterclockwise. the tv will become darker
Just a Black screen
needs a Y-Sustain board, about a 300 dollar part, unless you have a warinty, also try turning the tv on, after you get a green light, unplug the tv, after 15 seconds plug it back in, sometimes will make tv come back on
Top Daewoo Televison & Video Experts
David Shaub
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
