Question about Sony PlayStation 2 (PS2) Console
PSP2 slimline We cannot save to the memory card. When we go to browser to check it says not data. The memory card has ben used for approx 18 months. Thanks!!
Posted by Lorette on
Anonymous
Maybe your memory card has been carrupted, recommend you to get a new brand new one, as it will most likely be needed to be formated but that's highly impossible to do unless you speak to the manufacture of the console that deals with it. If you have data stored on the memory card you should be contacting the the menufacture and say if it is possible to retrieve your data stored on you memory card (PS2).
Hope that helps :)
Posted on Oct 28, 2007
I'm playing PSone games on my Ps2 and I am using a playstation one memory card. My ps2 loads from the memory card, but when I try to save data onto my ps1 memory card the ps2 freezes on the load screen.
YOU PROBABLY DON'T HAVE ENOUGH MEMORY ON YOUR PS1 CARD AND THE PS2 DOES'T KNOW HOW TO TELL YOU THIS BECAUSE IT WAS ONLY PROGRAMED TO SAY NOT ENOUGH MEMORY WITH A PS2 MEMORY CARD. TO PLAY OFF YOU SAVED DATA TRY TRANSFERRING YOUR MEMORY TO A COMOUTER THEN TO A PS2 MEMORY CARD... BEST OF LUCK
Jul 31, 2010 | Sony PlayStation 2 Slimline Console
My canon EOS 40D with 18 - 55 IS , when continuous shooting mode is selected, slows down after taking 6 shots. However as per the spec its capable of taking 75 jpegs or 17 RAW images.Please resolve this...
Slow down after taking 6 RAW files ...
A RAW file is Approx. 12.4MB.
The memory usage is approx. 74,4 MB
The internal memory (Buffer) has a size for up to 75 JPEG compressed images.
Which size has the smallest jpg?
JPEG/Small: Approx. 1.2MB (1,936 x 1,288)
The Buffer is approx. 80 MB.
The data are calculated under Canons laboratory conditions.
The maximum Burst (the 17 shoots) means that the camera is writing to the card and the buffer is full. Than the cam will stopping taking pictures.
Which kind of Card do you use?
Check the spec for the card (write speed) and maybe buy a faster card.
Jun 07, 2009 | Canon EOS 40D Digital Camera
Our memory card has corrupt data how do we get rid of it.
There are a lot of reasons data on a ps2 memory card can get corrupted. There is no way to completely get rid of them, but they barely take up any room on the card itself. The only risk is that there is a hightened chance that anything else you put on there could be corrupted at some point.
Apr 08, 2009 | Sony PlayStation 2 Slimline Console
No data display on memory card
open the memory card the connector could have slide back just upen memory card up has 2 screws then should pop open and slide the small chip forward
Jan 20, 2009 | Sony PlayStation 2 (PS2) Console
Manuel for Barbie explorer with tips and explication
PS1 games will not save to a PS2 memory card. You require a PS1 memory card.
Dec 08, 2008 | Vivendi Universal Barbie Explorer for...
Memory Card Slot Fault
Please take it immediately to the nearest authorized service center
Aug 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Memory card
it could be a glitch in the memory card, because a similar problem happen with my gamecube memory card and when i save data on it, it won't keep the data so i don't use it anymore. so a solution could be to buy 2 new memory cards and save the same data on both so if one has the same problem, you have backup data. if that solution does not work it could be the games or the console.
Apr 26, 2008 | Sony PlayStation 2 (PS2) Console
PS2 SLIM LINE CONSULE
Try copying save data from memory card 1 to memory card 2. Then start a new game but don't save,. turn off console then back on and load the data that you have copied, This should work
Mar 02, 2008 | Sony PlayStation 2 Slimline Console
Ps2 will not save ps1 games...
no u need to use a ps2 card i hd the same problem
Jul 30, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
