Question about Samsung X15 Notebook
Who can show me how to fix a short circut - Samsung X15 Notebook
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    That would depend on where the short circuit occurred, please provide more information
The computer says the immobilizer coil is open/short
Did you reset the computer. Usually disconnecting the battery for about 10 minutes should do it. If this does not fix it, you need to recheck your work. Something you did has caused the message. Did you short circut a wire, burn a fuse, forget to reconnect something? The immobilizer probably works by immobilization of the vehicle's coil circut. Thus, causing the computer message to display about the coil issue. Try reset computer of vehicle should work.
Apr 05, 2013 | Volvo S40 Cars & Trucks
Short circuting the rest of my home
There is a short on the elements or the thermostats in the machine, remove top cover and check fro broken wire.
May 01, 2010 | Saeco VIA Venezia
Laptop short circut
A short circuit could cause several different problems with your computer, most of which will require a new motherboard, processor, or both. Is it not powering on at all? If not, then your motherboard is most likely fried. I would suggest taking it to a local computer shop, or you could contact my business and arrange to send it in to be diagnosed and checked over. See MADHATTER COMPUTERS
Mar 22, 2010 | HP Compaq Presario CQ50-140US NoteBook
The Laptop will display the Sony Vaio logo, then a blank screen.
wait can anyone show me how to fix a short circut on a vaio
Jun 10, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Amp in protect mode how to fix
good in mode 2 protects from damaging unit u probaly have output wires touchin or inpt wires touching or shorted speaker if does not fix problem diconnect car batt 4 2min this resets pwm circut if no fix u probbaly have shorted opt transitors not expense 2 repair 4parts go2 nte semiconductor.com tran 2/3$ apice probally need 2 4 good luck
Apr 08, 2009 | Car Audio & Video
How do i fix an open SPOUT circut
replace the jumper in the connector for the shorting bar located near the ignition module.
Apr 02, 2009 | 1988 Ford Taurus
'99 F250 Windows, air and radio all stop working together sharp turn
there is probably a short in that circut use a volt meter to check for a short in all the circuts that run through that fuse
Nov 07, 2008 | 1999 Ford F250 Regular Cab
Samsung X15 Notebook Logo
160 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
