Candy FP855 Electric Single Oven Logo
Question about Candy FP855 Electric Single Oven
Child lock We can't get chillock off
Gaark
    New Friend:
  • 50 Answers
I can't find any mention of a child lock in the manual:
https://drive.google.com/open?id=1Ja2o9qZPTI809jaklqZFyIuHtspje_cNC0egEcUE6cf0TJ0Sc888U_0Q3s0OrYgE9iepD1Oq3feZZNKX
It seems to only lock when it is in self-cleaning mode @ ~320 degrees centigrade
Posted on Nov 24, 2015
I have a Sholtes oven FI6326 THE DOOR IS BLOCKED AND CANT BE OPEN
Was the child safety lock accidentally set?
Child safety device
The child safety function can be used to lock the oven
controls.
To activate the child lock, press the
ACTIVATE and press "OK" to confirm. To deactivate the
child lock, follow the same procedure but select
DEACTIVATE. The child lock may be activated whether the
oven is on or off. The child safety device may be deactivated
when the oven has finished cooking and in all situations
described above.
Oct 02, 2020 • Ovens
My aeg oven has a child lock feature which I can't turn off could you please help
Which model do you have? For the AEG Competence B9820, you toggle the Child Lock on and off by pressing and holding the Selection Clock and - buttons simultaneously until the Child Lock changes state. See https://www.manualslib.com/manual/611343/Aeg-Competence-B9820-4.html?page=45 . For the BE7314401, press clock and down arrows for ~2 seconds until you hear a chime and the lock turns on or off. https://www.manualslib.com/manual/444474/Aeg-Be7314401.html?page=22 has the details.
Please add a comment with the model number for direction specific to your oven. I will attempt to determine if there is a different combination to enable or disable the child lock feature. Note: at least one AEG microwave/grill uses Press "Micro+Grill" once. Then press "Clear/Stop" 5 times to toggle the child lock on and off.
I hope this helps.
Jan 06, 2016 • AEG Ovens
U1863 neff oven child lock does not turn off
you have to switch quickly 3 times beetween off and light on position.
Dec 11, 2015 • Neff Ovens
2answers
Turn off child lock
Can you identify the model of the oven you need help with or anything like that? Not all child locks on ovens are configured to function or be utilized the same way.
Sep 22, 2013 • Ovens
B1542 child lock
Can you check Enr and repost, model number is not recognised
Feb 22, 2013 • Neff Ovens
2helpful
2answers
How do I remove the child lock message on my Panasonic Inverter Microwave?
Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
Aug 20, 2011 • Ovens
1helpful
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 • GE Ovens
8helpful
2answers
How do I switch off child lock from my neff oven 1641
So, you should have a "-s-" being displayed if you have the child lock on.
The switch for selecting the oven mode( oven, fan oven, grill etc)
-from its off position, turn it one click left so the light comes on, and then click it back to off. Do this three times in quick succession. The "-s-" should now have disappeared and you can use your oven again.
Regards,
Steve.
Top Candy Ovens Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
ADMIN Eric
ADMIN Eric
Are you a Candy Oven Expert? Answer questions, earn points and help others
