Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out
before it boils. Took it apart (Tamper Proof TORX, available from
Snap-On, Canadian Tire, probably most auto parts places that also sell
tools). The On-Off switch has a mechanical lock out for the lid being
open and also for when it is not mounted on the base. The kettle also
has three bi-metallic temperature switches. One shuts off the kettle
after it has boiled long enough. The other two sit up against the
element assembly adjacent to each end of the heating element.They
protect against boiling an empty kettle by sensing the higher element
temperture when there is no water to conduct away the heat. In the case
where the lights flicker and go out, but the switch stays 'On' these
are the likely culprit.
In my kettle the contacts did not line up
correctly. Instead of making good contact they were only partially
overlapping like a couple of the olympic rings or a couple of rings
from the Audi logo. This resulted in a localized increased resistance
and high heat in one of the contact holders which eventually melted the
surrounding plastic. At that point the wires going to the element
behaved a bit like springs which forced the contact holder further out
of alignment until it all became hot enough to trigger the thermal
switch.
I fixed it by bending the contact holder, which is fused
into the now hardened plastic, to the optimal position and hopefully it
will not generate enough heat to remelt the plastic or trip the thermal
switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
