Question about Electrical Supplies
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 differemt locations?
I need the ability to wire a security motion detection light between two 3-Way light switches (already installed - wired currently as single pole single throw - why I dont know). I would like the result to be that each light switch has the ability to turn on the light full, or has the the ability to turn on the light switch to motion detection. Alternatively if this isnt possible my motion light is the type that when you flip the light switch shortly it will turn on for a period of time and then turn off. Alternatively the switches would be to turn the motion detection on and off from each light switch without having to go to each light switch to turn it on. The way the contractor wired it was that if the 3Way switch was flipped in one place - it had to be flipped back in that same switch and the other switch waa not useful except on/off with the other switch being in an exact state. Please help. Specific models of lights that help with this problem and links too them would be highly useful and specific diagrams for wiring would be highly useful. The contractor and home builder (who will be nameless for now can't seem to get this right after a year of trying.) Heartspeace
Posted by Hearts Peace on
Gil Shultz
  • 3,388 Answers
One of the switches needs to be a 4-way then the PIR will act as any other switch. The downfall is if the lights are on and motion is sensed they will turn off.
My preference is to connect the contacts of the security device across the travelers of the three way circuit. The travelers are probably the red and black in the three conductor cable. When motion is detected the lights will turn on regardless of the settings of the three way switches then after timeout they will turn off. If they are turned on with one of the three way switches nothing will happen when the motion detector turns on except you cannot turn the lights off until the security device has turned off.
I hope this helps. The motion contacts need to be isolated from the motion detector power.
Posted on Apr 29, 2014
5 Related Answers
Anonymous
  • 76 Answers
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Posted on Jun 27, 2009
Anonymous
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Posted on Jan 29, 2010
Anonymous
SOURCE: wiring diagram 3 way motion detector switch
mike
can you send me a picture of how you wired your switch..its driving me crazy...
[email protected]
Posted on Nov 04, 2010
Anonymous
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Posted on Nov 23, 2010
  • 18438 Answers
SOURCE: Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 different locations?
Here is a page of diagrams: http://www.do-it-yourself-help.com/3_way_switch_wiring.html
You have to use a 3 way switch on both sides. You should be able to get a motion light that has an always on feature. To activate the feature then you need to turn the light on off on fast and then it stays on. Ceck with home depot or someplace like that for lights with that feature. IF not then you are going to need to run another circuit.
Posted on Feb 20, 2014
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
I have a motion detection plug in security light, is it possibel to get it to stay on all the time?
if then light is on all the time what is the point of having a motion detector unit as it is designed to switch on a light when motion is detected
the light switch on when there is no motion but as soon as detected the light comes on primarily to light the way for you or to scare off intruders
having the light on all of the time is a waste of energy
Sep 04, 2017 | The Home Security
Motion light detection wiring
Black wire to constant power
Blue wire to load (to your light)
Green wire to Ground
Feb 20, 2014 | Leviton R01-PR180-1LI Decora 180 Degree...
Feb 20, 2014 | Electrical Supplies
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 18, 2013 | Electrical Supplies
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Instructions to wire a cooper light model number MS35 rain tight
1) Copy following link for wiring diagram of 2-light outdoor motion sensor.
http://waterheatertimer.org/How-to-wire-switches.html#motion
2) Existing light fixture will have 2 wires: Connect wiring as shown on link above, then keep light switch turned ON.
Jan 21, 2013 | Hardware & Accessories
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
Hi my question is motion spot light has has two black wires one from each light and two white from each light and one red from the motion detecter which is connected to the black wires there are two wires...
The red wire from motion detector connects to both of the black wires from the lights. The black wire from the motion detector connects to the incoming black wire from the switch or source. The white wire from the motion detector connects to both of the white wires from the lights and to the incoming white wire from the switch or source (all white wires are under one wirenut).
Dec 18, 2010 | Home
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Electrical Supplies Logo
258 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
