Question about Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio
I BOUGHT THE CX 3600HP 2 YEARS AGO. IT WOULD STOP WORKING FROM TIME TO TIME AND NOW IT WON'T WORK AT ALL. WHO DO I CONTACT ABOUT SENDING IT BACK FOR REPAIRS
Posted by MARY ERDLITZ on
Jim Verge
    New Friend:
  • 60 Answers
Great Question. I'm not sure if Galaxy would work on a Connex . Copper Electronics has a repair department and would probably fix it for you. I'd offer but I don't have a lot of spare time right now. It's probably the power connection inside of the radio or one of the legs on the main volatage regulator broke loose from the pc bpaurd. That's a common problem with those radios.
Posted on Feb 21, 2014
Why does the red light for antenna stay on
This means that your swr is high. you can damage the radio using it in this condition, check antenna and coax for damage or misinstallation
Feb 27, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
I have a connex cx-3600hp cb and it sounds like it has no power
your power switch it faulty as there is a drop in voltage
does the meters dim down?? then the voltage supply past the power switch it dropping as it draws more current or... the audio ic has damage or one of its associated capactors sometimes a diode can become leeky its used for AM modulation also
Feb 25, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
Need more receive
Use a longer antenna or get it higher..
102" whip for mobiles.
maco v 5/8, army big stik, or Bandit for base. or a long beam 5 or 6 element type.
for example..
May 05, 2013 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
After using the computer twice,it stopped working.we changed batteries to no avail. it was bought dec2009.smyths was contacted where it was bought,but couldnt be replaced as it had gone out of stock....
Usually the manufactures warranty covers material defects for a limited time, and ranges from 90 days to 3 years. I have never seen a warranty for a computer more than 2 years personally, and you bought the computer 8 years ago. Unfortunately I think you will need to pay for the repairs yourself.
Dec 01, 2017 | Bob The Builder Toys
2 sets purple hdd rails missing
I'm sorry Patrick but there seems to be some confusion here. FixYa is a website where you ask questions concerning various products, and we try to answer them.
FixYa is not directly involved with any manufacturer, and does not do warranty work, or provide parts.
Jul 31, 2009 | Chieftec CX-01B-B-SL-OP Mid-Tower Case
Speedometer and odometer not working 92 audi 100
I had similar problems with speedos in two 1990 Audi 100s, it was some time ago, but the contacts on the circuit boards on the back of the speedo deteriorate and do not give a good contact. I bought second hand speedos, only to find they had similar problems, eventually it was very easy to fix, I shaved matchsticks to chisel points and pushed them into the circuit boards to add pressure on the contacts and improve connection. After that repair drove the cars for a few years and the problem did not recur. It was a long time ago and I cannot remember exactly where the matchsticks were placed but look for soldered points near the edges of the boards. Regards, Michael
Nov 22, 2008 | 1992 Audi 100
Will not turn on
I contacted Garmin and they had me remove the microchip inside and see if that would fix the problem. It did not. So they instructed me to send it back in for repair. They gave me a return number and then ended up replacing the unit with a new one. My unit was under a year old so it was no charge.
Jun 15, 2008 | Garmin eTrex Legend Cx GPS Receiver
Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio Logo
82 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
