Freezers Logo
Mauveen Stone Posted on Feb 20, 2014
Power failure for 21hours think freezer thawed then froze would food still be edible & safe
Power failure for 21 hours, think food thawed then refroze is it safe to eat.
Chabe
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Feb 23, 2014
Chabe
Contributor
Level 1:
New Friend:
Answers
41
Questions
Helped
8609
Points
74
Hi
Food are not that bad after defrosting that long and again frozen. It also depends on how good you know your food as the taste might differ.
5 Related Answers
Anonymous
  • 410 Answers
  • Posted on Dec 20, 2007
SOURCE: Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 04, 2009
SOURCE: HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Anonymous
  • 1136 Answers
  • Posted on May 23, 2009
SOURCE: Freezer is running but food is thawing
If this is a self defrosting freezer, check amd make sure the evaporator fan motor is running and make sure there is no frost buit up on the back panel. Please let me know if either of these are the case so I can assist you further.
Thanks
Vic
Anonymous
  • 363 Answers
  • Posted on Jul 28, 2009
SOURCE: Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Anonymous
  • 97 Answers
  • Posted on Apr 05, 2010
SOURCE: FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
2answers
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
3helpful
Hotpoint freezer, High temp light on & all food thawing
It's probably the defrost timer is getting stuck in the defrost mode. What it does it it periodically interrupts power to the compressor and sends power to the defrost coils to allow any frost on the cooling coils to melt to keep them clear of ice build up. This is typically a mechanical timer and sometimes the motor fails and it stop turning and if it fails in the defrost mode, the compressor never turns back on no matter how warm the freezer is.
You can confirm it is the timer, by tracing the wires from the compressor to a little 2 by 2 inch box which is the timer. On one side there should be a round hole with a plastic cam. You should be able to turn that cam with a flat screw driver or a coin. Just give it a slight turn until you hear a click. After you turned the cam, the compressor should start. If it does, then it is the timer.
Jun 29, 2010 • Freezers
1helpful
FREEZER NOT FREEZING AND F RIDGE FEELING WARM
Before you throw out this refrigerator, try a few simple tests.
First, open the freezer while the compressor is running and listen for the fan running. If it is not, this could be your problem. Replacement fans can be ordered from on-line parts stores, a local appliance repair shop, even ebay.
Second, try turning off the refrigerator and letting the coils in the freezer thaw completely. Of course, move your food to a safe place for a few hours while you thaw the freezer. If you really get ambitious, remove the rear panel from the freezer and look to see if the coils are frozen. If they are, thaw them and dry the freezer compartment completely. Reassemble the freezer and restart the refrigerator.
If the problem reoccurs, you may have a problem with your defrosting circuit.
My Maytag side by side fridge freezer is leaking at the bottom and ice is collecting at the bottom of the freezer. I cannot find any model number but think it's about 6 years old
The drain is clogged behind the wall in the freezer you can do one of three things take the back wall inside the freezer off and thaw the drain in the bottom and clear it out,Pay someone else to do this,or you can mover your food for a day unplug the unit open the freezer door and leave it off for 24 hours allowing the ice to clear from the drain,seems to happen about every five or six years with Maytags..
2answers
Thanks
Vic
May 23, 2009 • Freezers
2answers
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
1helpful
2answers
Defrosting???
your food should not thaw in a frost free freezer. but I can not tell you why it is thawing, sorry.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
