Well that is surely problem with your e-mail server, can you restart the password? If so I highly advice you to do it, since thats fixing your problems. Also check updates for new IMAP / POP3 and SMTP server since I remeber the time when they used to change those incom. outcom. system ports with my ISP's :)
Sir/Madame please rate my solution that would be really kind from you. :)
Welding thin wall tubing requires skill and a special kind of welder. Google you local welding companies. Could have a problem if any plastic components are near to the break. DIY option could be find a smaller steel tube to slot in side broken tube and pop rivet.
Well, unless you remeber it you cannot get it. Your option is to reset the router and start over. Give new password and reset the sytem name, and remeber to secure the wireless portion.
May be ur entering wrong password or id.....click on forgotten password....if u remeber ur correct mail id enter ur mail id....or u can answer the two questions and enter your date of birth.....if u enter it correctly it will let u change ur password n u can agin login using new password......hope this helps....
you will require windows cd to reset or remove the password,first boot with cd and you get option to press any key to boot with cd ,press any key now windows will start copying files ,dont worry we are not reinstalling windows so keep up the installation process till you get the screen which says installing devices and windows time will be approx. 39 minutes to complete installation quickly press Shift key+F10 this combination will stop windows installation and new window will pop that gives you option to reset and remove password. Now do as you like and remove windows cd , It is the best possible solution you may find in all of cyberspace ,no harm to computer is done ,i hope you will be happy to use this technique and help others as well.
POP server: pop3.live.com (Port 995) POP SSL required? Yes User name: Your Windows Live ID, for example [email protected] Password: The password you usually use to sign in to Hotmail or Windows Live SMTP server: smtp.live.com (Port 25 or 587) Authentication required? Yes (this matches your POP username and password) TLS/SSL required? Yes
