Question about Water Heaters
Low pressure coming from Hot Water Tap
I have a Worcester 34i Combi Boiler and recently the water is not as good coming out of the hot water tap, so i tested how many ltrs a minute i was getting from both cold and hot. The result of this was 15 ltrs a min from the Cold tap and 6 ltrs a min from the Hot tap. The manual says you should get around 10 ltrs a min from the hot water, so i am losing around 4 ltrs a min from the hot water and dunno why this is all off a sudden started to happen. I would be grateful if anyone could help or advise with what they think could possibly be the cause of this.
Posted by c_eaton3 on
  • c_eaton3
    c_eaton3 Feb 20, 2014
    Sorry it's a Worcester 24i
Alfred
    New Friend:
  • 10 Answers
Were is the water boiler located.
Posted on Feb 20, 2014
Testimonial: "It's located upstairs"
  • Alfred Feb 20, 2014
    Okay cause a lot of times when you have the hot water heater up stairs away from the bathroom it takes time for the hot water to get to the place. And when it has to go far it will loose some pressure. It is common
  • c_eaton3
    It doesn't have to go far it's in the next room to the bathroom
3 Related Answers
Anonymous
  • 104 Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
mixing valve must be replaced
Posted on Nov 02, 2008
gary1121
gary miller
  • 332 Answers
SOURCE: a trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
Posted on May 29, 2009
Anonymous
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
I have a Worcester 24di combi boiler and it's not working I have a red flashing tap light have represurised the pressure but still not working I have no heating or hot water can you help me please
Red flashing lights usually mean trouble.
There is not enough air getting to the combustion chamber, or the chimney is not working properly. (Stopped up flu)
If this is not a pretty obvious problem, it is better handled by someone who knows a lot more about it than us.
Feb 26, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Worcester 24i combi when in shower hot water flicks on and off can hear gas igniting and extinguishing
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Aug 06, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
I have a combi boiler and a 'popping' hot tap
the lock nut has either come loose under the handel or the 'o' ring and stem have loosened up, might this be a delta faucet? if so replace the cartridge "stem" and the o-ring and spring you will be fine,,
Jun 09, 2009 | Rheem Tankless water heater for 1-2...
A trickle of hot water from taps, central heating ok
May 18, 2009 | Water Heaters
Water Heaters Logo
157 people viewed this question
Top Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Water Heater Expert? Answer questions, earn points and help others
