Question about Brother IntelliFax-2820 Laser Fax
We just changed the toner in our fax, and now it's printing solid black pages out. Help!
Posted by wleger on
Sid
  • 483 Answers
Unplug the cable that connects the computer and printer together.
Plug the printer power cord into a wall outlet.
Print a self-test to determine if the problem is related to the printer, rather than the software.
If the problem occurs on the self-test page, replace the toner cartridge. A faulty or damaged cartridge may cause black pages.
Remove all accessories (cartridges, memory, I/O boards, etc.) and try to print a self-test again. Faulty accessories may cause black pages to be produced.
If the problem persists, the printer may need to be serviced.
Thanks
Fame !
Posted on Jun 10, 2009
Why is it printing solid black pages?
The replacement toner cartridge may have been installed incorrectly.
Mar 31, 2016 | Ricoh Aficio SP 100e Laser Multifunction...
Solid black lines on the right side of page
Try sliding the blue tab on the drum unit side-to-side. If that does not cure it, you need a new DRUM UNIT
Oct 02, 2009 | Brother IntelliFAX 4100 Laser Fax
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
Black Prints
The toner might be bad, because the old cartridge is working fine.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Xerox DocuPrint P12 Laser Printer
Dell 1720 lazer printer only printing solid black pages
The corona wire is not charging the drum properly. Try pulling the toner cartridge out and then re-seating it. If this doesn't work, try a new toner cartridge as the corona wire is usually included in the cartridge.
If you are using a refill toner, there's an outside chance that the supplier put toner with the wrong electric charge in the cartridge. Again, changing the cartridge should fix this(assuming the replacement is from another batch).
Jul 25, 2009 | Dell 1720dn Laser Printer
Brother Intellifax 2600 - Solid black pages
Black pages are indicative of a bad drum. A failing drum basically can't be charged anymore. Since the toner cartridge can't discern what part of the drum is calling for toner, it simply fills the whole page with toner, creating the black pages you describe. You should check the drum, and corona wire and clean both. If the problem returns, you have a bad drum and should replace it.
Jul 09, 2009 | Brother IntelliFAX 2600 Fax
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Brother intellifax 4100 prints full page all black
Good chance the High voltage power supply is bad. Not worth repairing. A new unit costs about 259.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 08, 2006 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
254 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
