Question about Arcsoft TotalMedia Extreme - Windows for PC
Cannot detected the device or use by other application
Posted by christopher... on
Big Steve
  • Arcsoft Master
  • 1,087 Answers
You can get help at
https://ssl.arcsoft.com/totalmedia-extreme/how-to-use-totalmedia-extreme.html
Posted on Feb 21, 2014
Device not detected or use by other application
Go to 'Windows Task Manager' (ctrl+alt+del) and click the 'processes' tab and (if possible) stop only devices affected and retry. Be careful not to stop devices/drivers required by windows or any application in use otherwise windows/application will stop working.
If a device is not in use and still not detected or is wrongly reported, get the latest drivers and install them first. You may check device settings and make changes as required. If all else fails and you have the original software, try re-installing it after a proper uninstall.
Feb 20, 2014 | Arcsoft TotalMedia Extreme - Windows for...
Bluetooth driver cant be installed
Please chose the exact driver for your laptop model. It is unlikely that your Bluetooth device is broken. Please check the bluetooth device item in the Control Panel. If it is detected by the system, then all you need is download the driver for this Bluetooth device and its application. Some Bluetooth device need separate and or proprietary application.
Feb 12, 2014 | Lenovo G585 15.6inch Laptop
Bluetooth device not detected in device manager and not even in bios. bluetooth device shown none in bios. what can be done to solve the problem.
if the bluetooth device is not detected in the BIOS, chances are, your laptop did not ship with a bluetooth device. Try to go to support.dell.com and check the original system configuration to verify if your system indeed came with a bluetooth card. you can also check with dell support about it. if you have verified the card is available and it is enabled in the BIOS, try to remove and reconnect the card and if it is still not detected, you may have to get a new bluetooth card or request for warranty service/replacement if applicable.
Sep 06, 2010 | Dell Vostro 1014 Laptop Computer
Paginakabit ko yung smart bro kit ko sa computer hindi na dedetect nung computer as in...wala man lang lumalabas na ''the usb device not detected''as in parang ala talaga akong ikinabit sa computer...
try to connect it to different USB port.if your smart bro is not detected again, unplug the device(smart bro), uninstall the features of the smart broadband, restart your computer, after the loading of windows plug your smart bro now and wait for it to detect, after 5mins and your computer doesnt detect your device then repeat the uninstallation of your smart broadband application and reinstall also your Universal Serial Bus Controllers and restart. nagkaganyan na din ung smart bro ko.
Feb 22, 2010 | Computers & Internet
My blackberry is just sayingblockerase6 Reset
The Block Erase 6 Reset error may result from corrupt data on your BlackBerry device.
To resolve this problem, you need to complete the steps:
Reload the BlackBerry Device Software by following these steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Connect the BlackBerry device to the computer.
  3. Open BlackBerry Desktop Manager.
  4. Complete one of the following:
    1. If the Application Updates Available window appears, click Update Now. The Application Loader wizard appears.
    2. If the Application Updates Available window does not appear, double-click Application Loader. The Application Loader wizard appears.
  5. Click Next.
  6. If prompted, enter your BlackBerry device password and click Next.
    When the Application Loader wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation.
  7. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  8. Click Next.
  9. If the On the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry device.
  10. Click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Inspite of this if you find the same error, you need to follow the steps:
  1. Remove the battery from the BlackBerry device.
  2. If a media card is inserted in the BlackBerry device, remove it.
  3. Connect the BlackBerry device to your computer using the USB cable.
  4. Open BlackBerry Desktop Manager and click Option > Connection Settings.
  5. In the Connection Settings window, click Detect. Make sure the BlackBerry device is detected.
  6. Close the Connection Settings window.
  7. In BlackBerry Desktop Manager, double-click Application Loader.
  8. In the Application Loader wizard, click Next to start the loading process. The Device Application Selection screen appears displaying the applications available to load onto your BlackBerry device.
  9. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  10. Click Next. The Completing the Application Loader Wizard appears listing the applications to be installed and removed from the BlackBerry device.
  11. Click Advanced.
  12. Select the Erase all application data check box, and then click Next.
  13. Select the check box beside Do not automatically backup the application data during the loading process. This check box is selected because the data on the BlackBerry device may be corrupt.
  14. Reinsert the battery into the BlackBerry device.
  15. On the Application Loader wizard, click Next to proceed with the loading process.
  16. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  17. Reinsert the media card if one was removed earlier.
  18. Close the Application Loader wizard.
Nov 16, 2009 | RIM BlackBerry 7290
The volume won't work anymore, it says the audio device supported by this application is not detected, the application will exit. was working grand yesterday
it,s saying the audio Device used by this Application ( Program )
Is not detected.
The problem most likely is with the program i.e media-Player, Cyberlink Power DVD Et,c.
uninstall and re-install your Audio/Music Application.
Also check the devices/Drivers are not corrupt or not installed.
Mike @ Compurepair,
Nov 05, 2009 | Dell Inspiron 6400 Notebook
I woke up this morning to find find the screen of my new BlackBerry Curve reading "JVM Error 545 incompatible or corrupt filesystem." It was charging all night. Unless my roommate messed with it, I have...
The BlackBerry Device Software is corrupted.
u need to reinstall the software.
Install the latest version of the BlackBerry Device Software on the BlackBerry smartphone.
The BlackBerry Desktop Manager will not detect the BlackBerry smartphone in this state. To force the BlackBerry Desktop Manager to detect the BlackBerry smartphone, run the Application loader tool. For instructions on how to force the BlackBerry Desktop Manager to detect the BLackBerry smartphone.
Perform following steps
BlackBerry Desktop Manager 4.5.0 and later
  1. Remove the battery from the back of the BlackBerry smartphone.
  2. Connect the BlackBerry smartphone to the computer using a USB cable.
  3. In BlackBerry Desktop Manager, double-click Application Loader.
  4. Click Start under the Update Software heading
  5. The Device Password dialog will display. If the BlackBerry smartphone has a password enabled, enter the password. If the BlackBerry smartphone does not have a password, leave this field empty.
  6. Click OK.
  7. If prompted with a list of Available Updates, choose the latest software version by selecting the corresponding check box and then click Next.
  8. Click the Settings button under the Device backup and restore options.
  9. Make sure that the Back up device data automatically during the installation process check box is not selected.
  10. Make sure that the Delete all application data and Erase all currently installed applications check boxes are both selected.
  11. Click OK on the Settings dialog.
  12. Insert the battery into the back of the BlackBerry smartphone.
  13. In the Application Loader wizard, click Next to proceed with the loading process.
  14. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  15. Insert the memory card, if applicable.
  16. Close the Application Loader wizard.
If you are getting problem in installation of configuration kindly contact me
Please Rate !
Sep 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
Mionet unable to detect Lifecam 7000
A camera icon will show up at the bottom of your My Resources in MioNet. If the camera does not appear, then a manual scan is required. To scan for a new camera, go to the MioNet application, select File, then click "Scan for Cameras and new Devices…" MioNet will report any changes in the computer configuration.
If the camera isn't detected and an icon is not available, then there may be two devices interfering with a scan:
1. Built-in webcam: MioNet does not support built-in webcams. This device should be disabled in Windows Device Manager, the computer rebooted, and a new "Scan for Cameras and new Devices…" performed with the USB webcam. Once the USB webcam is detected by MioNet, the onboard webcam can be re-enabled and the computer rebooted.
2. TV tuner card: MioNet also does not support TV tuner cards. This device should be disabled in Windows Device Manager, the computer rebooted, and a new "Scan for Cameras and new Devices…" performed with the USB webcam. Once the USB webcam is detected by MioNet, the TV tuner card can be re-enabled and the computer rebooted.
3. If the camera is being used by another program, MioNet will not be able to detect it. Please confirm no other program, including the camera view in Windows control panel, is not using the camera.
May 24, 2009 | Microsoft LifeCam NX-6000 Webcam
Acer 5610z
i assume your laptop is Aspire 5610z.
try to check in device manager first.
is your camera is detected in device manager ? it should be under imaging device.
if it not detected, mean something wrong with your camera.
if it is detected, checked the manufacture.
if it is microsoft, it's mean wrong driver. it should be bison, suyin or logitect. in this case try to install the correct driver.
you can download the driver and application from www.acerpanam.com
May 27, 2008 | Acer Aspire 5100 Notebook
Active sync is not detecting my mobile Nokia N81
You are useing the wrong software!
You need:
Nokia Nseries PC Suite
1x1trans.gif Nokia Nseries PC Suite is a PC software product designed to help you make the most of your Nokia Nseries multimedia device. The collection of applications in Nokia Nseries PC Suite reflects the essence of Nseries devices: the solution provides you with all the applications you need to manage your videos, images, and music.
Nokia Nseries PC Suite is optimized for Nokia Nseries devices. Nevertheless, the software is compatible with the same devices as Nokia PC Suite.
http://europe.nokia.com/A4577197
Mar 06, 2008 | O2 Xda IIs Pocket PC
Arcsoft TotalMedia Extreme - Windows for PC  Logo
216 people viewed this question
Top Arcsoft Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
