Question about HP PSC 1410v All-in-One Printer
Connect wireless network
What else is needed to complete this task
Satellite p35 will not go to wireless
Might not have a wireless card installed ??
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop.
However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings."
This will give you options for modifying how you connect to the Internet.
Select "Connect to a Network" or "Show Network Status and Tasks."
Both selections will show you whether you are disconnected from the wireless network.
Select "Manage Network Connections."
This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection.
Engage the wireless connection.
Turn your wireless switch to "On," then right-click on the wireless network connection.
Select "Connect/Disconnect."
Wait for the IP address acquisition.
It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address.
When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength.
Launch your favorite browser to access the Internet using the wireless connection.
http://forums.computers.toshiba-europe.com/forums/thread.jspa?threadID=18365
Aug 25, 2013 | Computers & Internet
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
How to load Integrated Wireless LAN on my toshiba satellite a45-s1202
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop. However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings." This will give you options for modifying how you connect to the Internet. Select "Connect to a Network" or "Show Network Status and Tasks." Both selections will show you whether you are disconnected from the wireless network. Select "Manage Network Connections." This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection. Engage the wireless connection. Turn your wireless switch to "On," then right-click on the wireless network connection. Select "Connect/Disconnect." Wait for the IP address acquisition. It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address. When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength. Launch your favorite browser to access the Internet using the wireless connection.
Feb 03, 2013 | Toshiba Satellite A45-S1202 Notebook
I recently replaced my old Belkin N150 Wireless Router with a new Cisco E3200 Wireless Router. After doing so, all of my wireless devices work (9 total) EXCEPT for my (2) Acer Aspire One Netbooks. The...
Remove and recreate the wireless network connection
  1. Click on Start, and then Control Panel
  2. Double click on Network Connections
  3. Right-click the wireless network connection, and click Properties
  4. Click the Wireless Networks tab
  5. Under Preferred networks, click the wireless network, and then click Remove
  6. Click View Wireless Networks
  7. Under Network Tasks, click Refresh Network List
  8. Under Choose a wireless network, click the wireless network that you want to connect to, and then click Connect
In Windows, there is a power mode setting for the wireless driver that may help this issue. Follow the instructions below.
  1. Go to Control Panel, System, click the Hardware tab and select Device Manager.
  2. Click the + next to Network Adapters and double click on the wireless network adapter.
  3. Click on the Advanced tab, select Power Save Mode from the list on the left.
  4. Change the Value on the right to Off.
    The default setting is Maximum, which may cause issues similar to those described.
Check to see if this has resolved the connectivity issue. If it has not, the following steps may need to be completed.
  1. Click on Start, Settings, Control Panel
  2. Double click Network Connections
  3. Right-click your wireless network connection, and click Properties
  5. Under Preferred networks, click the wireless network, and click Properties
  6. Click the Authentication tab, click to clear the "Enable IEEE 802.1X authentication for this network" check box, and then click OK twice.
Sep 23, 2011 | Acer Aspire 5100 Notebook
I don't know how to use wifi on my Toshiba A45 S120
Feb 11, 2010 | Toshiba Satellite A45-S120 Notebook
How to open ethernet??
Task 1 - Turn on the Discoverable option on the BlackBerry smartphone Complete the following steps:
  1. On the Home screen of the BlackBerry smartphone, click Options > Bluetooth.
  2. Display the menu and click Options.
  3. Set the Discoverable field to Yes.
  4. Display the menu and click Save.
Task 2 - Pair the BlackBerry smartphone and the computer On the computer, complete the following steps:
  1. Go to Control Panel > Bluetooth Devices.
  2. Click Add.
  3. Select the My device is set up and ready to be found check box, and click Next.
  4. When the BlackBerry smartphone is detected, select the check box next to the BlackBerry smartphone, and click Next.
  5. Select the Let me choose my own passkey option.
  6. Type a passkey in the field provided, and click Next.
  7. On the BlackBerry smartphone, type the same passkey from Step 6, then click the trackball.
  8. On the computer, when the Completing the Add Bluetooth Device Wizard screen appears, click Finish.
  9. On the BlackBerry smartphone, when prompted to accept an incoming Bluetooth connection, select Don't Ask Again, and click Yes.
Task 3 - Set up the Internet access point name (APN) Note: You only need to perform this task the first time that you set up the Internet APN.
Note: If you are running Windows Vista, select Classic View.
  1. Go to Control Panel > Phone and Modem Options.
  2. Select the Modems tab.
  3. Select Standard Modem Over Bluetooth Link, and click Properties.
  4. Select the Advanced tab.
  5. In the Extra initialization commands field, type the following: AT+CGDCONT=1,"IP","<your Internet APN( for eg: aircelgprs)>"<cr>
Task 4 - Configure Dial-Up Networking Note: You only need to perform this task the first time that you configure Dial-Up Networking.
  1. Go to Start > Settings > Network Connections.
  2. Right-click Bluetooth DUN connection, and select Properties.
  3. Select the Networking tab.
  4. Select Internet Protocol (TCP/IP).
  5. Click Properties.
  6. Click Advanced.
  7. Select the General tab, and clear the Use IP Header Compression check box.
  8. Click OK to close all open windows.
  9. Go to Start > Settings > Network Connections.
  10. Double-click New Connection Wizard.
  11. Click Next.
  12. Select Connect to the Internet, and click Next.
  13. Select Set up my connection manually, and click Next.
  14. Select Connect using a dial-up modem, click Next.
  15. Select Modem - Standard Modem Over Bluetooth link, and click Next.
  16. If the Select a Device screen appears, select the Modem - Standard Modem check box, and click Next.
  17. Clear the ISP Name field blank, if necessary, and click Next.
  18. Complete the appropriate step below:
    • If the BlackBerry smartphone operates on General Packet Radio Service (GPRS) or Enhanced Data Rates for Global Evolution (EDGE) networks, type *99# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Universal Mobile Telecommunications System (UMTS) networks, type *98# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Code Division Multiple Access (CDMA) or 1x/Evolution Data Optimized (EVDO) networks, type #777 in the Phone number field, and click Next.
  19. Type the user name and password provided by your wireless service provider. If your wireless service provider has confirmed that this information is not required, leave the fields blank. Click Next.
  20. Click Finish.
Task 5 - Connect the computer to the Internet using Dial-Up Networking Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session may interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Click Start > Settings > Network Connections > <Name of the new connection>.
  2. Type the user name and password provided by your wireless service provider. If your wireless service provider does not require this information, leave the fields blank.
  3. Click Dial.
Oct 05, 2009 | RIM BlackBerry 7730
Im having trouble linking my router with my laptop
HI! if the problem is wireless connection, check the wireless settings of your router if there is a wireless security, u need this information to connect ur laptop to wireless network, then right click the wireless network icon on the lower right of ur task bar and it will pop the wireless network windows, on the left side of this windows, look for related task and select on change the order of the prefered network, it will pop the wireless connection properties and u have to remove all the name on the preferred network and once its done view available network and connect the the ssid of ur network and if there is a security u need to enter the password, if this process dont solve, uninstall the drive of your wireless adapter and re install it..then do the first step again..
Aug 12, 2009 | D-Link DI 514 Wireless Router (DI-514)
I cannot connect to the internet using wifi
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
Dec 01, 2008 | Computers & Internet
Laptop connect to public wireless network, but not internet
Sometimes they set the wireless to be unsecured. But you have to pay to use them.
Please check with the hotel staff about setting it to use.
If its completely free, double click the network icon on the task bar, click support tab and click repair.
Nov 14, 2008 | Toshiba Satellite A205-S4617 Notebook
HP PSC 1410v All-in-One Printer Logo
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
