Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Had the same problem. Removed the filter and pressure washed it. Code 90 is gone.
Posted on Jul 01, 2012
There may be hair or debris stuck on the flow sensor OR you may have the input and output reversed. The input comes from the lower of the 2 holes in the side of the pool and hooks up to the middle area of the 8111. The output comes out by the electro cell and hooks to the higher of the two holes in the pool. The flow sensor can be found just inside the electro cell component. it should swing freely when you press it.
Posted on Aug 24, 2009
You may need to contact the dealer who sold you the pool. Tell him you nee to get "water flow" to
filter your pool water so that it can sanitized.
Once you do as he instructed and it still isn't
working have him send you help free of charge.
Posted on Jun 10, 2009
Sep 11, 2011 | Intex Automatic Salt Water System for ...
Aug 24, 2011 | Intex Automatic Salt Water System for ...
Jun 16, 2011 | Intex Automatic Salt Water System for ...
Aug 27, 2010 | Intex Automatic Salt Water System for ...
Aug 26, 2010 | Intex Automatic Salt Water System for ...
Jun 07, 2010 | Intex Automatic Salt Water System for ...
Jun 06, 2010 | Intex Automatic Salt Water System for ...
Jul 22, 2009 | Intex Automatic Salt Water System for ...
Jul 11, 2009 | Intex 2000 GPH Salt Water Filtration Pump...
Jun 09, 2009 | Intex Automatic Salt Water System for ...
Aug 18, 2014 | Intex Automatic Salt Water System for ...
666 people viewed this question
