NO SIGNAL
you will not be able to get the network signals if there is some problem in the network pin of your handset ... or you will also face the problem if this network pin is not in contact with the circuit board of your cell ...
there may also some firmware problem this can be solved by giving the restore factory settings ....
after giving this restore factory settings restart your phone and check whether you are getting the network signals or not ..
if you still persist the same problem then you need to open your handset and check the network pin status .. check whether the network pin is in good condition or not and the end of this pin might be broken check it ...
if it is in good condition then just fit your handset again correctly so that the network pin ends touches the circuit board ...
after this if you check you will be able to get the signals ..
if the network pin is broken then just replace the network pin with the new one ...
do this if you are good in opening the handset ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
